Printers reset upon finishing prints in 3.5.1 and 3.5.2
I could not find any reference to this issue so I figured I would post something (sorry if this is already a known issue). So this didn't happen in 3.4.5 or before, but when a print finishes, rather than going to idle status the printer(s) reset. This is at the end of every print. It also does not occur on machines running just a MB6HC. Including M122 responses for the machines that have the issue. So across three machines:
Printer 1: 3.5.2 - CoreXY - Standalone Mode - No Issue
Printer 2: 3.5.2 - Cartesian - Standalone
RepRapFirmware for Duet 3 MB6HC version 3.5.2 (2024-06-11 17:13:58) running on Duet 3 MB6HC v1.01 (standalone mode)
Board ID: 08DJM-9P63L-DJMSS-6JTD8-3S46M-9VFV8
Used output buffers: 1 of 40 (40 max)
Static ram: 155360
Dynamic ram: 122324 of which 0 recycled
Never used RAM 68308, free system stack 192 words
Tasks: NETWORK(1,ready,37.2%,153) ETHERNET(5,nWait 7,0.0%,400) HEAT(3,nWait 6,0.0%,321) Move(4,nWait 6,0.0%,323) CanReceiv(6,nWait 1,0.0%,771) CanSender(5,nWait 7,0.0%,334) CanClock(7,delaying,0.0%,346) TMC(4,nWait 6,9.5%,53) MAIN(1,running,53.1%,444) IDLE(0,ready,0.0%,29), total 100.0%
Owned mutexes:
Last reset 13:59:38 ago, cause: software
Last software reset at 2024-08-13 20:19, reason: User, Gcodes spinning, available RAM 63316, slot 0
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0043c000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
Error status: 0x00
Aux0 errors 0,0,0
MCU temperature: min 38.1, current 39.8, max 42.2
Supply voltage: min 24.1, current 24.2, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
Events: 0 queued, 0 completed
Driver 0: standstill, SG min n/a, mspos 296, reads 10356, writes 14 timeouts 0
Driver 1: standstill, SG min n/a, mspos 296, reads 10357, writes 14 timeouts 0
Driver 2: standstill, SG min n/a, mspos 8, reads 10357, writes 14 timeouts 0
Driver 3: standstill, SG min n/a, mspos 8, reads 10357, writes 14 timeouts 0
Driver 4: standstill, SG min n/a, mspos 8, reads 10360, writes 11 timeouts 0
Driver 5: standstill, SG min n/a, mspos 8, reads 10360, writes 11 timeouts 0
Date/time: 2024-08-14 10:18:51
Slowest loop: 16.08ms; fastest: 0.08ms
=== Storage ===
Free file entries: 19
SD card 0 detected, interface speed: 25.0MBytes/sec
SD card longest read time 4.2ms, write time 30.8ms, max retries 0
DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
no step interrupt scheduled
Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0
=== DDARing 0 ===
=== DDARing 1 ===
Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
Heater 1 is on, I-accum = 0.0
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
SBC is idle in state(s) 0
Daemon is idle in state(s) 0
Aux2 is idle in state(s) 0
File2 is idle in state(s) 0
Queue2 is idle in state(s) 0
Q0 segments left 0, axes/extruders owned 0xc0000003
Code queue 0 is empty
Code queue 1 is empty
=== Filament sensors ===
check 0 clear 276563284
Extruder 0 sensor: ok
=== CAN ===
Messages queued 453434, received 2015164, lost 0, errs 1, boc 0
Longest wait 1ms for reply type 6041, peak Tx sync delay 386, free buffers 50 (min 49), ts 251892/251891/0
Tx timeouts 0,0,0,0,0,0
=== Network ===
Slowest loop: 34.03ms; fastest: 0.03ms
Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
HTTP sessions: 2 of 8
= Ethernet =
Interface state: active
Error counts: 0 0 2 1 1783 0
Socket states: 5 2 2 2 2 0 0 0
=== Multicast handler ===
Responder is inactive, messages received 0, responses 0Printer 3: Cartesian - Standalone
RepRapFirmware for Duet 3 MB6HC version 3.5.1 (2024-04-19 14:30:55) running on Duet 3 MB6HC v1.01 (standalone mode)
Board ID: 08DJM-9P63L-DJ3T0-6JTDJ-3SJ6P-T83MA
Used output buffers: 3 of 40 (31 max)
Static ram: 155208
Dynamic ram: 123244 of which 0 recycled
Never used RAM 67540, free system stack 202 words
Tasks: NETWORK(1,ready,25.7%,176) ETHERNET(5,nWait 7,0.2%,392) HEAT(3,nWait 6,0.3%,321) Move(4,nWait 6,0.0%,324) CanReceiv(6,nWait 1,0.9%,772) CanSender(5,nWait 7,0.0%,334) CanClock(7,delaying,0.0%,346) TMC(4,nWait 6,79.0%,54) MAIN(1,running,142.8%,444) IDLE(0,ready,0.0%,30), total 249.0%
Owned mutexes:
Last reset 09:01:17 ago, cause: software
Last software reset at 2024-08-14 01:17, reason: User, Gcodes spinning, available RAM 64052, slot 2
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
Error status: 0x00
MCU temperature: min 49.3, current 50.8, max 52.3
Supply voltage: min 23.9, current 24.0, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
12V rail voltage: min 12.2, current 12.3, max 12.3, under voltage events: 0
Driver 0: standstill, SG min n/a, mspos 8, reads 30627, writes 11 timeouts 0
Driver 1: standstill, SG min n/a, mspos 880, reads 30619, writes 19 timeouts 0
Driver 2: standstill, SG min n/a, mspos 16, reads 30620, writes 19 timeouts 0
Driver 3: standstill, SG min n/a, mspos 784, reads 30620, writes 19 timeouts 0
Driver 4: standstill, SG min n/a, mspos 176, reads 30620, writes 19 timeouts 0
Driver 5: standstill, SG min n/a, mspos 8, reads 30628, writes 11 timeouts 0
Date/time: 2024-08-14 10:18:34
Slowest loop: 8.74ms; fastest: 0.08ms
=== Storage ===
SD card longest read time 3.2ms, write time 3.8ms, max retries 0
=== DDARing 0 ===
=== DDARing 1 ===
Bed heaters -1 1 2 3 4 5 6 7 8 9 -1 -1, chamber heaters -1 10 11 -1, ordering errs 0
Heater 12 is on, I-accum = 0.0
Q0 segments left 0, axes/extruders owned 0x80000003
=== CAN ===
Messages queued 292381, received 2468336, lost 0, errs 1, boc 0
Longest wait 2ms for reply type 6053, peak Tx sync delay 388, free buffers 50 (min 49), ts 162389/162388/0
=== Network ===
Slowest loop: 13.09ms; fastest: 0.03ms
HTTP sessions: 1 of 8
= Ethernet =
Error counts: 0 0 0 1 0 0
Responder is inactive, messages received 0, responses 0 -
@Andrew2087 how do you know they reset? neither of the M122 show a reset
@jay_s_uk Print again does not appear, all motors are no longer homed, and babystepping is cleared
This would be the time at which the print finished on Printer 2:
This was not from user interaction with the printer -
I'm also including the printers' ending gcode for reference (I can also share configs if that might be helpful):
Printer 1: CoreXY, single tool, running MB6HC, DOES NOT RESET Upon print completion
; layer end
M106 S0 ; turn off cooling fan
M104 S0 ; turn off extruder
M140 S0 ; turn off bed
G1 X0 Y270; part removal
; Build SummaryPrinter 2: Cartesian, IDEX, P3 and P4 are for Mimic/Mirroring and are only created on the printer if using Mimic/Mirror Mode. P1 and P2 are the left and right head respectively
; layer end
T0
G28 XUY
M568 P1 R0 S0
M568 P2 R0 S0
M568 P3 R0:0 S0:0
M568 P4 R0:0 S0:0
M190 S0; Turn off bed
M141 S0 ; turn off chamber
G0 Z785;Printer 3: This printer is made up of 9 small bed heaters + a pellet extruder (hence the Nozzle heater, Middle, and Upper heaters), (the middle and upper heaters are configured as chamber heaters) - I am aware that this printer does disable the X and Y motors during the ending gcode, as stated above, Z is also disabled and babystepping is cleared.
; layer end
T0
G28 XY
M106 P0 S0 ; shut off part cooling vent
G10 P0 S0 R0; Set Active and standby temps for Nozzle heater
M141 P1 S0 R0; Set Active and standby temps for Upper Heater
M141 P2 S0 R0; Set Active and standby temps for Middle heater
M84XY ; disable motors
M144 P1
M144 P2
M144 P3
M144 P4
M144 P5
M144 P6
M144 P7
M144 P8
M144 P9 -
@Andrew2087 Do you have a stop.g file? If so what is in it?
@gloomyandy That was it. Didn't see that stop.g now runs at the end of all prints since 3.5b1 regardless of M0 being present and stop.g was set with an M999 (I assume when it was set up on printers 2 and 3 it was thought that it was for an emergency stop situation not the end of a print). Thank you for your help!
undefined dc42 marked this topic as a question
undefined dc42 has marked this topic as solved
