M32 at right click please.... (macro)
Hi *,
I realized that a gcode file gets slightly different executed when I place it in the gcode folder than it is located in the macros folder. (I store my test print files in a macro sub folder)
It would be nice if there would be an optin in the DWC to "print" a file ( M32 "/macros/_Test_Files/pa_pattern-0--0-08.gcode") with a mouse click, like a new menu entry in the menu which appears after a right click.What do you think?
Cheers, Chriss
If it's a print job, and not a macro, store it in the print job location.
@Phaedrux That is what I want to avoid. The macros folder is in git and shared between printers etc. And I do not want to search the needle in the job hay stack every time I need one of the files.
Cheers, Chriss
