    Can I switch hardware wiring pinout in config?
    • 3DPotterundefined
      3DPotter
      On the Duet 2 expansion slot lets say for Pin 5) E2_STEP and Pin 6) E2_DIR,
      Is there a way to switch them with each other?- To tell the control board to switch them.
      I understand this is a very strange ask, and the correct answer is to just fix my wiring, but this would save me some time if I can just change a config setting of some kind.
      Asking so we can fix prototypes faster, as we make a lot of new devices.
      https://3dpotter.com/
      The only dedicated 3D ceramic printer using real clay.
      https://www.instagram.com/3dpotter/
      https://www.youtube.com/c/3dpotter/
      https://www.facebook.com/3dpotter/
      https://www.reddit.com/user/3D_Potterbot
      jay_s_ukundefined dc42undefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @3DPotter
        @3DPotter i suppose you could in the software. It would mean compiling your own release etc though
          dc42 administrators @3DPotter
          @3DPotter as Jay says, you would need to compile your own firmware to do that. The pins used are defined in file src/Config/Pins_DuetNG.h. A further possible complication is that the current code assumes that all step pins are on Port D, so if you swap a step pin with another pin that is not on Port D then a code change would be needed too.
          • 3DPotterundefined 3DPotter marked this topic as a question
          • 3DPotterundefined 3DPotter has marked this topic as solved
