under voltage warnings
Ive recently been getting under voltage warnings when shutting off 24v power via relay and leaving 5 v on using pson pin. the 5v side is on a going into board at pson 3 pin header via a buck converter powered by the same powersupply as 24v side. its been wired like this for 3 years this is new behavior with 3.5.1. the 5v buck has its own direct wires to the psu.
its a 2017 vintage duet 2 ethernet.
m1228/23/2024, 3:42:13 AM: m122: === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.5.2 (2024-06-11 17:13:43) running on Duet Ethernet 1.02 or later Board ID: 08DGM-9T6BU-FG3S0-7JTD6-3SJ6S-9A6VH Used output buffers: 1 of 26 (23 max) === RTOS === Static ram: 23384 Dynamic ram: 70452 of which 0 recycled Never used RAM 15924, free system stack 108 words Tasks: NETWORK(1,ready,41.5%,202) HEAT(3,nWait 5,0.1%,307) Move(4,nWait 5,2.4%,298) MAIN(1,running,56.0%,713) IDLE(0,ready,0.0%,29), total 100.0% Owned mutexes: === Platform === Last reset 26:04:45 ago, cause: software Last software reset at 2024-08-22 01:37, reason: User, Gcodes spinning, available RAM 20580, slot 0 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x08 Aux0 errors 0,0,0 MCU temperature: min 28.2, current 28.3, max 31.2 Supply voltage: min 23.5, current 24.4, max 24.5, under voltage events: 2, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/48/48, gc cycles 0 Events: 3 queued, 3 completed Driver 0: standstill, SG min n/a Driver 1: standstill, SG min n/a Driver 2: standstill, SG min n/a Driver 3: standstill, SG min n/a Driver 4: standstill, SG min n/a Driver 5: Driver 6: Driver 7: Driver 8: Driver 9: Driver 10: Driver 11: Date/time: 2024-08-23 03:42:08 Cache data hit count 4294967295 Slowest loop: 370.61ms; fastest: 0.14ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 249.7ms, write time 1.9ms, max retries 0 === Move === DMs created 83, segments created 22, maxWait 2330ms, bed compensation in use: none, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 1.00 no step interrupt scheduled Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0 === DDARing 0 === Scheduled moves 293008, completed 293008, hiccups 3, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 2 is on, I-accum = 0.1 === GCodes === Movement locks held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Q0 segments left 0 Code queue 0 is empty === Filament sensors === check 31361803 clear 384926029 Extruder 0: pos 2343.87, errs: frame 17 parity 0 ovrun 212 pol 2 ovdue 0 === Network === Slowest loop: 206.40ms; fastest: 0.04ms Responder states: HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 1 of 8 Interface state active, link 100Mbps full duplex Socket states: 5 2 2 2 2 2
config
; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Printer" ; set printer name M80 C"pson" ; Network M552 P192.168.0.242 S1 ; enable network and set IP address M553 P255.255.255.0 ; set netmask M554 P192.168.0.1 ; set gateway M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P4 S0 D2 ; U axis M569 P3 S1 D2 ; X axis M569 P10 S0 T2.5:2.5:20:20 ; Z1 ext driver M569 P11 S0 T2.5:2.5:20:20 ; Z2 ext driver M569 P2 S1 D2 ; Y axis on dbl port M569 P8 R0 S0 T2.5:2.5:20:20 ; extruder 0 ext driver M569 P9 R0 S1 T2.5:2.5:20:20 ; extruder 1 ext driver M569 P0 R-1 ;DRIVER DISABLED AND NOT REPORTING M569 P1 R-1 ;DRIVER DISABLED AND NOT REPORTING M584 X3 Y2 U4 ; set drive mapping M584 Z10:11 M584 E9:8 M669 K0 ; select cartesian mode M92 X 80.720 Y 80.64 U80.64 M350 X256 Y256 U256 I1 M350 Z16 I0 M350 E16 I0 M92 Z2072.72 M92 E415.0:415.0 M566 X1200.00 Y1200.00 U1200.0 Z10.00 E600.00:600.0 P0 ; set maximum instantaneous speed changes (mm/min) M203 X5000.00 Y5000.00 U5000.0 Z50. E1000.00:1000.0 ; set maximum speeds (mm/min) M201 X700.00 Y700.00 U 700.0 Z15.00 E200.00:200 ; set accelerations (mm/s^2) M906 X1500.00 Y1500.00 U1500.0 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X-181.0:181.0 Y-150:150 Z0:300 U-181.0:181.0 ; set axis minima ; Endstops M574 X1 S1 P"xstop" ; configure active-high endstop for low end on X via pin xstop M574 Y1 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop M574 U2 S1 P"e0stop" ; configure active-high endstop for low end on Z via pin e0stop M574 Z0 P"Zstop" ; Z-Probe ;M558 P8 C"e0stop" H12 F500 T1500 R1 ; disable Z probe but set dive height, probe speed and travel speed ;M557 X-80:80 Y-90:70 S10 ; define mesh grid ;G31 X17 Y-49 P1000 Z3.775 ;probe not installed ;M671 X-255.0:255.0 Y 0:0 S5.0 ; Heaters M950 H3 C"nil" ; disable heater 3 and free up the associated pin M950 H4 C"nil" ; disable heater 4 and free up the associated pin M950 H5 C"nil" ; disable heater 5 and free up the associated pin M950 H6 C"nil" ; disable heater 6 and free up the associated pin M950 S4 C"exp.heater3" ; create output/servo port 0 attached to heater 3 M950 S5 C"exp.heater4" ; create servo port for nozzle brush on heater 4 M950 P6 C"exp.E4_STOP" M950 P7 C"exp.E5_STOP" ;BED HEATER M950 H0 C"bedheat" T0 M308 S0 P"bedtemp" Y"thermistor" A"Heater 0" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp M140 H0 ; map heated bed to heater 0 M143 H0 S110 ; set temperature limit for heater 0 to 120C M307 H0 R0.775 K0.393:0.000 D12.77 E1.35 S1.00 B0 M570 H0 P10 T10 S5 ;TOOL HEAT ;HEATER ONE X HEATER M950 H1 C"e0heat" T1 M308 S1 P"e0temp" Y"thermistor" T100000 B3950 ; configure sensor 1 as thermistor on pin e0temp M307 H1 R3.458 K0.359:0.000 D10.87 E1.35 S1.00 B0 V24.0 M143 H1 S300 ; set temperature limit for heater 1 to 280C M570 H1 P15 T15 S5 ;U HEATER HEATER 2 M950 H2 C"e1heat" T2 M308 S2 P"e1temp" Y"thermistor" T100000 B3950 M307 H2 R2.623 K0.229:0.000 D17.37 E1.35 S0.80 B0 V24.2 M143 H2 S300 M570 H2 P15 T15 S5 ; Fans M308 S10 Y"mcu-temp" A"MCU" ; defines sensor 10 as MCU temperature sensor M950 F2 C"fan2" Q25000 M950 F1 C"fan1" Q25000 M950 F0 C"fan0" Q25000 ; create fan 0 on pin fan0 and set its frequency M106 P2 H10 T24:45 C"Case Fan" L32 X255 B1 M106 P1 H1 L64 X255 C"U Tool Fan" T45:100 B1 ; set fan 0 value. Thermostatic control is turned ON M106 P0 H2 L64 X255 C"X Tool Fan" T45:100 B1 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 S"X Tool Single" D0 H2 F1 ; define tool 1 G10 P0 X0 Y0 Z0 ; set tool 1 axis offsets G10 P0 R0 S0 ; set initial tool 1 active and standby temperatures to 0C M563 P1 S"U Tool Single" D1 X3 H1 F0 ; define tool 2 G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets G10 P1 R0 S0 ; set initial tool 2 active and standby temperatures to 0C ; Custom settings are not defined ; Miscellaneous M575 P1 B57600 S1 ; enable support for PanelDue M591 D0 P3 C"e1stop"E3.0 R60:140 S0 ; filament monitor connected to E0_stop ;M501 ;M308 S10 P"spi.cs1" Y"dht22" A"DHT22 TEMP" ;DHT22 TEMP SETUP ;M308 S11 P"S10.1" Y"dhthumidity" A"DHT22 RH" ;DHT22 RH SETUP M80 ;TURN ON PWR RELAY M290 R0 S0 ;RESET BABY STEPS ;M556 S100 X-1.8 ;CALIBRATION XY ;M402 ;PROBE UP m107 M572 D0 S.8 ; pressure advance
@Miss-Rebekah If you are shutting off the VIN supply then the undervoltage warning is to be expected. I cant remember which firmware version that introduced the warnings.
