array index out of bounds
Hi. I have been having spi problem and probably because of an ooold sc card. SO Y reflashed a new one. It was imposible to do it using the image of the new bloworm version (I have already created a post about it in the firmware section)
So I flashed an image I have. Installed updated, restores configurations. Rebooted and now I having this error:Error: in file daemon.g line 4: line 0: array index out of bounds
My daemon.g file has this (to clarify, this was working before the reflash with no error, and I was already on the 3.5.2 version)
Duet 3, SBC version 3.5.2 running
Thabnks ina dvance for the help
@Tinchus The problem was there. I have another post relñated to problemns flashing the latest raspi images. May be is something related to that?
I have flashed now the 64 bits version, uploaded the system files again and everything is "normal" (still not able to update DWC)
@Tinchus update, there is something wrong. At pruinter startup I get:
Error in start-up file daemon.g line 4: line 0: array index out of bounds
I just noticed something else: im still getting the error. Also sometimes I get a "nable to activate endstops" or soemthing like that.
When any of these errors appear, is like config.g was not loaded because I can not see any tool on the interface.... entering to edit config.g saing and resttarting, solves everythingIm using the image of 64 bits of raspi, the opther images dont work (a post aboiut it is creasted), can this be the problem?
