    Failed to get file list - Service Unavailable
    Duet Web Control
    • TypQxQundefined
      TypQxQ
      Hi!
      Upgraded my Duet 2 WiFi from a older 3.4 beta to latest and greatest today.
      After uploading a file, be it in DWC or trough PrusaSlicer, it doesn't show up in the job list and when refreshing I get the error:
      Not sure if it's DWC or where this comes from. After waiting a while, refreshing works again.
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.5.2 (2024-06-11 17:13:43) running on Duet WiFi 1.02 or later + DueX5
      Board ID: 08DGM-956GU-DJMSN-6J1FJ-3SN6T-KTNHD
      Used output buffers: 16 of 26 (26 max)
      Static ram: 23384
      Dynamic ram: 74276 of which 0 recycled
      Never used RAM 12364, free system stack 120 words
      Tasks: NETWORK(2,nWait 6,14.3%,195) HEAT(3,nWait 5,0.1%,319) Move(4,nWait 5,0.3%,298) DUEX(5,nWait 5,0.0%,23) MAIN(1,running,85.2%,717) IDLE(0,ready,0.1%,29), total 100.0%
      Owned mutexes: WiFi(NETWORK)
      Last reset 02:11:20 ago, cause: software
      Last software reset at 2024-08-26 16:49, reason: User, Gcodes spinning, available RAM 11684, slot 1
      Error status: 0x14
      MCU temperature: min 38.3, current 39.1, max 42.4
      Supply voltage: min 23.9, current 24.3, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
      Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/96/96, gc cycles 0
      Events: 0 queued, 0 completed
      Driver 0: standstill, SG min 153
      Driver 1: standstill, SG min 0
      Driver 2: standstill, SG min 0
      Driver 3: standstill, SG min n/a
      Driver 4: standstill, SG min 0
      Driver 5: standstill, SG min 0
      Driver 6: standstill, SG min 185
      Driver 7: standstill, SG min n/a
      Driver 8: standstill, SG min 0
      Driver 9: standstill, SG min 0
      Driver 10:
      Driver 11:
      Date/time: 2024-08-26 19:00:51
      Slowest loop: 267.71ms; fastest: 0.17ms
      === Storage ===
      Free file entries: 9
      SD card longest read time 12.2ms, write time 228.7ms, max retries 0
      DMs created 83, segments created 11, maxWait 842538ms, bed compensation in use: mesh, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 1.00
      no step interrupt scheduled
      Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0
      === DDARing 0 ===
      Scheduled moves 9696, completed 9696, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
      Heater 0 is on, I-accum = 0.2
      Heater 1 is on, I-accum = 0.3
      Movement locks held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Q0 segments left 0
      Code queue 0 is empty
      === Filament sensors ===
      check 2921242 clear 26867682
      Extruder 0 sensor: no filament
      === DueX ===
      Read count 0, 0.00 reads/min
      === Network ===
      Slowest loop: 247.23ms; fastest: 0.07ms
      Responder states: HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
      HTTP sessions: 1 of 8
      === WiFi ===
      Interface state: active
      Firmware version 2.1.0
      MAC address 5c:cf:7f:76:66:58
      Module reset reason: Turned on by main processor, Vcc 3.40, flash size 4194304, free heap 39528
      WiFi IP address 192.168.1.205
      Signal strength -55dBm, channel 8, mode 802.11n, reconnections 0
      Clock register 00002002
      Regards, Andrei
        jay_s_uk @TypQxQ
        @TypQxQ that's a long write time on the SD card. I would suggest refreshing the SD card (don't forget to back everything up) or replace the SD card for a newer one
