    Config Tool 3.5.4, Heated bed SSR Q value
    Config Tool
    • Zoltan3Dundefined
      Zoltan3D
      I recently modified the heated bed of my 1000x1000x1100 printer.
      Indeed, I went from a single 2000W heater, whose temperature is managed by a basic external thermostat, to 4 silicone plates of 500x500 each with its individual control.
      (Finally the two at the back are coupled together)
      They are each controlled by an individual SSR by the Out1 Out2 Out3 ports.
      I managed to configure them perfectly, but I found no way to add the Q parameter to the M950 in the configurator.
      I have to remember to add them manually after each upload of the config.
      Indeed, I have to use Q5 to avoid overloading the SSRs
      Is it possible to add a frequency box on the Config Tool?
      Many thanks
      jay_s_ukundefined chrishammundefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @Zoltan3D
        @Zoltan3D one for @chrishamm
        • chrishammundefined
          chrishamm administrators @Zoltan3D
          @Zoltan3D It's been possible to set the M950 Q value in the configtool, you need to click on the heartbeat icon and then apply the frequency change:
          Duet software engineer
