    M291 T value to return a result
    Firmware wishlist
    • moth4017undefined
      moth4017
      When using the M291 with a T value for time out , i carnt seem to capture this event .
      M291 R"Do you want to Run G29" P"your choice" S4 T5 J1 K{"Yes", "Reuse height map" ,"clear heightMap"} F5
          if input = 0
              echo input
              G29    ; use saved height map
          elif input = 1
              echo input
              G29 S1 P"/sys/heightmap.csv"; load previous height map
          elif input = 2
              echo input
              G29 S2 ; clear height map
          else
              echo "no selection pressed" ;G29 S1 ; load previous height map
              echo input
      selection 1 returns this:-
      8/31/2024, 4:02:19 PM M292 R{1} S21
      1
      time ouit selection nothing returned
        dc42 administrators @moth4017
        @moth4017 I think this is related to https://github.com/Duet3D/RepRapFirmware/issues/959. Timing out is equivalent to pressing the Cancel button, if there is one.
        benagricola created this issue in Duet3D/RepRapFirmware
        closed [FeatureRequest]: Allow `M291` to set `result` to `-1` when blocking modal "Cancel" clicked. #959
        moth4017undefined 1 Reply Last reply Reply Quote 0
        • moth4017undefined
          moth4017 @dc42
          have i done this correctly to capture the "Time out"
          M291 R"Do you want to Run G29" P"your choice" S4 T5 J2 K{"Yes", "Reuse height map" ,"clear heightMap"} F5
              if input = 0
                  echo input
              elif input = 1
                  echo input
              elif input = 2
                  echo input
              elif input = -1
                  echo input
          • gloomyandyundefined
            gloomyandy @moth4017
            @moth4017 What you are seeing is the current expected behaviour, there is a feature request to change this, but I do not think it has been implemented yet (or if there is any commitment to implement it).
            • gloomyandyundefined gloomyandy referenced this topic
