    good stepper choice?
    • cosmowaveundefined
      cosmowave
      Hello
      I'd like to replace the steppers on my delta which runs with a DUET2.
      I'm not sure if the following steppers are a good choice. The specs should be well inside the recommendation written in the DUET3D Documentation.
      Eventually, someone can help me?
      The stepper is a Motion King 17H2A9425
      Thanks in advance.
      Mankati FSXT+, DeltaTowerV2, E3D MS/TC
      jay_s_ukundefined dc42undefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @cosmowave
        @cosmowave look fine to me https://docs.duet3d.com/en/User_manual/Connecting_hardware/Motors_choosing
          dc42 administrators @cosmowave
          @cosmowave that's OK but more powerful than you are likely to need. The 48mm 2.3A version would retain full torque to higher speeds.
          cosmowaveundefined 1 Reply Last reply Reply Quote 1
            cosmowave @dc42
            @dc42 @jay_s_uk
            Thank you both for the help!
            I will try with the 48mm 2.3A version.
