    Shorted Hotend Fan = no fan work anymore
    • AS-3D Druck
      AS-3D Druck last edited by
      Hi there i made a mistake while i wired my new Noctua Fan.
      I shorted the + and - of my Wires directly and something blowed away (was like a silten blob) and it smelled realy awfull.
      Now the Duet Wifi still works except for the Fans.
      Any Idea what onboard gave up?
      Best regards
      AS-3D Druck / Andre
        If you shorted out one of the controlled fan outputs, the corresponding fan mosfet will have failed. You will probably be able to see which one. See https://duet3d.com/wiki/Connector_and_spare_part_numbers#Fan_mosfet.
        If none of the fan outputs is working, then the trace connecting the V_FAN pin on the fan voltage selector jumper to +VIN on the power input terminal block has probably fused. You can bypass it with a piece of wire on the underside of the board.
        • AS-3D Druck
          No one of my Fans is working anymore 😞
          Is there a way to replace the Part to get everything working like before?
          Bypassing it sounds realy bad but can you show me on a Picture how to do that anyway?
          (If i bypass it is it possible to control my Fans like before?)
          Best regards
          AS-3D Druck / Andre
            Use a multimeter to confirm that there is no longer any continuity between the two pins circled in red in this image. Then connect them together using a piece of insulated wire.
            • AS-3D Druck
              THX dc42
              My Fans are now running again.
              Best regards
              AS-3D Druck / Andre
