Equivalent to Klipper_Estimator for RRF available?
I use Orca to slice the models for my RRF printer and need to use a postprocessor which depends on more or less exact estimations of execution times for each move in the gcode file.
There is such a program for Klipper users called "Klipper_Estimator.exe" and I would need the equivalent to analyse a gcode in RRF flavor. I assume that the actual estimation calculations themselves would be similar but the program does not accept gcode generated for RRF due to some trivialities I think.
Does anyone know about such a program compatible with RRF gcode files?
@Triet You can simulate job files in DWC by right-clicking on an item and pressing "Simualte". When done, it will show a pretty accurate estimate of the print time in the job list and on the job progress page. Is that what you are looking for?
@chrishamm
Well, this is what one gets from Klipper_Estimator:$ ./klipper_estimator [config options] estimate ~/3DBenchy.data
Sequences:
Run 0:
Total moves: 42876
Total distance: 73313.01640025008
Total extrude distance: 3407.877500000097
Minimal time: 1h29m9.948s (5349.947936969622)
Average flow: 1.5321468696371368 mm3/s
Phases:
Acceleration: 27m4.291s
Cruise: 35m1.116s
Deceleration: 27m4.291s
Moves:
Layer times:
0 => 2.536s
... [some lines omitted for brevity]
48 => 4.834s
Kind times:
4m23.463s => FILL
2.639s => Other
18m0.185s => SOLID-FILL
28m29.706s => WALL-INNER
38m13.706s => WALL-OUTER(you might take a look at https://github.com/Annex-Engineering/klipper_estimator).
I am afraid that what the DWC outputs will not be enough, but I will check it.
Could I use that feature from a command line?
@chrishamm
I tried out the simulation in the DWC.
Actually, the simulation calculates more than just the total print time, since it shows duration for each layer grafically.
Is there a way to get that data as numerical values in a text file? Perhaps with a different granularity? -
@Triet Not out of the box but you could write a DWC plugin to generate a text file if you need one. Layer details are available in the
layers.[]
object model of DWC and DSF (only in SBC mode). -
@chrishamm OK, thanks.
