Laser engraving….
Hi everyone, and happy new year.
I'm trying to config my Delta printer for laser engraving. When I send M452 the printer switches in laser mode but it uses FAN 0 to output for laser beam.
How do I change the output to HEATER E1?
I tried the command M452 P2 R255 F200 but nothing happens. It gives me an error: P2 Bad Parameter.
Can anyone tell me how to config the right setting for the laser? Also, where do I put them in config.g?This is my config.g :
; generated by RepRapFirmware Configuration Tool on Thu Dec 28 2017 21:02:47 GMT+0100 (ora solare Europa occidentale); General preferences
M111 S0 ; Debugging off
G21 ; Work in millimetres
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000";*** The homed height is deliberately set too high in the following - you will adjust it during calibration.
M665 L369.184 R134.167 H368.971 B110 ; Set delta radius, diagonal rod length, printable radius and homed height
M666 X0.74 Y-0.81 Z0.06 ; Put your endstop adjustments here, or let auto calibration find them
M208 Z0 S1 ; Set minimum Z; Endstops
M574 X2 Y2 Z2 S1 ; Set active high endstops
M558 P5 R0.4 H5 F550 T6000 ; Set Z probe type to effector and the dive height + speeds
G31 P100 X0 Y0 Z-0.163 ; Set Z probe trigger value, offset and trigger height
M557 R110 S20 ; Define mesh grid; Drives
M569 P0 S0 ; Drive 0 goes backwards
M350 X64 Y64 Z64 E64 I0 ; Configure microstepping without interpolation
M92 X320.85 Y320.85 Z320.85 E390 ; Set steps per mm
M566 X1000 Y1000 Z1000 E1000 ; Set maximum instantaneous speed changes (mm/min)
M203 X18000 Y18000 Z18000 E1200 ; Set maximum speeds (mm/min)
M201 X1000 Y1000 Z1000 E1000 ; Set accelerations (mm/s^2)
M906 X1000 Y1000 Z1000 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeout; Heaters
M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
M143 H0 S100 ; Set temperature limit for heater 0 to 100C
M143 H1 S280 ; Set temperature limit for heater 1 to 280C; Tools
M563 P0 D0 H1 ; Define tool 0
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; Network
M550 PDelta Star ; Set machine name
M552 S1 ; Enable network
M587 S"fiore_wifi2" P"fiorello1" I192.168.0.24 J192.168.0.1 K255.255.255.0 ; Configure access point and IP addresses. You can delete this line once connected
M586 P0 S1 ; Enable HTTP
M586 P1 S1 ; Enable FTP
M586 P2 S0 ; Disable Telnet; Fans
M106 P1 S0 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P2 S1 I0 F500 H0:1 T50 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on; Custom settings
M572 D0 S0.25 ; Set control pressure nozzle; Miscellaneous
Which facility are you using to set the laser PWM: E values on the G1 commands, or M3 commands between the G1 commands?
Either way, you first need to make the E1 heater output (heater 2) available as a GPIO pin by sending M307 H2 A-1 C-1 D-1. After that:
- If you are using E values on the G1 commands, send M571 P2
- If you are using M3 commands, send your M452 P2 command after that.
