    SBC Brainrot
    Beta Firmware
    242
    • p8blrundefined
      p8blr
      Hey I'm wondering if there are any diagnostics I can run to help figure out why my Duet in SBC mode has slowed down significantly in the past week? I'm running a Raspberry Pi 5 8GB with a 6XD and various toolboards with 3.5.3-rc.1 and it was working great until this morning when I noticed that DWC has slowed down significantly, it freezes up every few seconds, and you can see it in the temperature graphs, macros take several seconds to start running, and gcode uploads freeze up.
      I should also mention that I've noticed this behavior come and go in the past, but I was happily surprised how fast latest firmware and pi images responded, up until this morning.
      Note: I'm using the Arc browser in Windows.
        Can you connect via SSH and send the htop command to view active processes and their resource usage?
        p8blrundefined 1 Reply Last reply Reply Quote 1
        • p8blrundefined
          p8blr @Phaedrux
          @Phaedrux
          There was a lot so I tried my best to fit it all here.
          This is the top few things when I sort by cpu usage
          I'm also noticing it will freeze for a few seconds, and then unfreeze. It happens in Putty and the DWC.
            Perhaps @chrishamm can spot anything notable in there. In the meantime, might be worth trying a fresh, high-perf SD card.
            p8blrundefined 1 Reply Last reply Reply Quote 0
            • chrishammundefined
              chrishamm administrators @p8blr
              @p8blr Those stats look pretty good to me. Since you said it's an issue when you upload files, I'd guess it's an issue with WiFi power saving. If it's connected via WiFi, try https://www.thedigitalpictureframe.com/stay-connected-enhancing-raspberry-pi-wi-fi-stability-by-turning-off-power-management/
              Duet software engineer
              • p8blrundefined
                p8blr @Phaedrux
                @Phaedrux I'm actually running it with a nvme drive on a pcie hat.
                • p8blrundefined
                  p8blr @chrishamm
                  @chrishamm I've actually got it connected via ethernet to my router, however, my laptop is on wifi. Would that matter? I'm about 20ft from my router.
                    @p8blr That's quite possible. You could connect your laptop using an Ethernet cable to your router and check if the lags persist.
