    Duet 2 Wifi Fan Issues
    • JRCLundefined
      JRCL
      Trying to use the fan ports on a Duet 2 wifi to control a 12V electromagnet. I have the fan jumper on the VIN selection and the board is powered at 12V. However, my always-on fans (just as a check) never turn on and I can't turn on the fan0 with M42 either. I checked both sets of pins with a multimeter and didn't get much of a reading, but unsure if you can given the PWM signal (though I thought I had before). M98 on my config yields no issues either. Any help is appreciated
      G90                                     ; send absolute coordinates...
      M83                                    	; ...but relative extruder moves
      M550 P"FSR Test Bench"                  ; set printer name
      M552 S1                                 ; enable network
      M586 P0 S1                              ; enable HTTP
      M586 P1 S0                              ; disable FTP
      M586 P2 S0                              ; disable Telnet
      M569 P0 S1				; physical drive 0 goes reverse
      M569 P1 S0				; physical drive 1 goes forward
      M584 X0:1                          	; set drive mapping
      M350 X16 I1                     	; configure microstepping with interpolation
      M92 X80.0           		; set steps per mm
      M906 X1000 I30                 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                         	; set idle timeout
      M208 X0 S1                        	; set axis minima
      M208 X267 S0                      	; set axis maxima
      ; EndStop
      M574 X1 S3 							; X endstop on low end with sensorless homing
      M915 X R0 F0
      ;Relays
      M950 F0 C"fan0" Q500					;tray electromagnets
      M106 P0 S1 H-1
      infiniteloopundefined droftartsundefined 2 Replies Last reply Reply Quote 0
      • JRCLundefined JRCL marked this topic as a question
      • infiniteloopundefined
        infiniteloop @JRCL
        @JRCL
        They are 'always on' as the name implies. Thus, G- or M-Codes have no effect.
        That's weird: According to these schematics, the V_FAN pins should carry 12V (well, depending on the V FAN JUMPER SELECT jumper position and the voltage supplied to VIN). The PWM fans are different: Here, the FAN# pins are actively switched to GND, the V_FAN pins should always be at 5V or VIN - depending on the V FAN JUMPER SELECT. Check the fuse VIN to Fans MiniBlade (see schematics).
        JRCLundefined 1 Reply Last reply Reply Quote 1
          droftarts administrators @JRCL
          @JRCL Check the 1A fan fuse, it may be blown. Also check you have a jumper on the 'V FAN JUMPER SELECT' pins. See the wiring diagram: https://docs.duet3d.com/duet_boards/duet_2_wifi_ethernet_maestro/duet2ndgen_connections_v1.0-1.5_d2.1.png
          Are you running the electromagnet directly from the fan port (probably way too much current) or via a relay?
          • JRCLundefined
            JRCL @infiniteloop
            @infiniteloop @droftarts It was the fan miniblade fuse! Should've checked this sooner but haven't blown many fuses yet, lesson learned. I had even swapped my Duet 2 wifi with another at a point so I thought no way both have a blown fuse....sure enough they both did. I think it was long before I was setting up this machine as the electromagnet has less than 1A draw on 12V, but I'll be double checking
            infiniteloopundefined dc42undefined 2 Replies Last reply Reply Quote 0
              infiniteloop @JRCL
              @JRCL
              How much less? The fuse can take 1A, but the MOSfets of the PWM fans are limited to 800mA IIRC, so you are possibly better off with a relay as @droftarts suggests. Anyway, you should provide a flyback diode.
                dc42 administrators @JRCL
                @JRCL the medium-current (i.e. fan) outputs on Duet 2 are rated 1A but can handle 1.5A for short periods e.g. when a fan is starting up. However, the entire fan power circuit (2 always-on output and two switched outputs) shares the fuse, which is normally 1A. You can increase it to 2A or even 3A if you are sure that the individual outputs are not overloaded.
                Duet 2 boards include flyback diodes on the fan outputs but not on the heater outputs.
