    Dual Motor Auto Square and Leveling
    CNC
    684
    • Alijambo73undefined
      Alijambo73
      Hi have a DND With 2 Y motors and 2 Z motors on a Duet3 6hc board. I want to be able to make adjustments when homeing to level the Z and Square the Y within the homey.g, homez.g, and home all files.
      My under rstanding is that to do this you need to create an axis for each motor.
      "M584 X0.0 Y0.1:0.3 Z0.2:0.4 U0.3 V0.4 P3 ; U=Y2 V=Z2 set axis mapping"
      I'm not positive that this is needed or if it is that I did it correctly. I have read that you can add M584 Y0.1 P5 to the homeing and this would split the Y axis to make the neccesary adjustments.
      Looking for a little guidance on this one and what would need to change in my homez.g, homey.g and hamoeall.g files.
      ; Smart Drivers
      M569 P0.0 S0 D2                    ; driver 0.0 goes backwards (X axis)
      M569 P0.1 S0 D2                    ; driver 0.1 goes backwards (Y axis)
      M569 P0.2 S1 D2                    ; driver 0.2 goes forwards (Z axis)
      M569 P0.3 S1 D2                    ; driver 0.3 goes forwards (U axis)
      M569 P0.4 S1 D2                    ; driver 0.4 goes forwards (V axis)
      ; Motor Idle Current Reduction
      M906 I30                           ; set motor current idle factor
      M84 S30                            ; set motor current idle timeout
      ; Axis
      M669 K0                            			; set Cartesian kinematics
      M350 X16 Y16 Z16 U16 V16 I1                 ; configure microstepping with interpolation
      M906 X1000 Y1000 Z1000 U1000 V1000          ; set axis driver currents
      M92 X100 Y100 Z400 U100 V400                ; configure steps per mm
      M566 X60 Y60 Z60 U60 V60                	; set maximum instantaneous speed changes (mm/min)
      M203 X12000 Y12000 Z3000 U12000 V3000       ; set maximum speeds (mm/min)
      M201 X600 Y600 Z60 U600 V60                 ; set accelerations (mm/s^2)
      M208 X0 Y0 Z-100 U0 V-100 S1             ; set axis minimum
      M208 X1248 Y2470 Z140 U2470 V140 S0      ; set axis maximum
      ; Kinematics
      ;M669 K0                            ; configure Cartesian kinematics
      M574 X1 S1 P"io1.in"        ; configure active-high endstop for low end on X via pin io2.in
      M574 Y1 S1 P"io2.in"        ; configure active-high endstop for low end on Y via pin io2.in
      M574 Z2 S1 P"io4.in"        ; configure active-high endstop for high end on Z via pin io4.in
      M574 U1 S1 P"io3.in"		; configure active-high endstop for low end on U (Y2) via pin io3.in
      M574 V2 S1 P"io5.in"		; configure active-high endstop for high end on V (Z2)via pin io5.in
      homeall.g
      ; homeall.g
      ; called to home all axes
      ; generated by RepRapFirmware Configuration Tool v3.5.4 on Mon Sep 09 2024 22:47:08 GMT-0600 (Mountain Daylight Time)
      ; increase Z
      G91                                                   ; relative positioning
      G1 H2 Z5 F7200                                        ; move Z relative to current position to avoid dragging nozzle over the bed
      G90                                                   ; absolute positioning
      ; home XY
      var xTravel = move.axes[0].max - move.axes[0].min + 5 ; calculate how far X can travel plus 5mm
      var yTravel = move.axes[1].max - move.axes[1].min + 5 ; calculate how far Y can travel plus 5mm
      G1 H1 X{-var.xTravel} Y{-var.yTravel} F6000           ; coarse home in the -X and -Y directions
      G1 H2 X5 Y5 F7200                                     ; move back 5mm
      G1 H1 X{-var.xTravel} Y{-var.yTravel} F300            ; fine home in the -X and -Y directions
      ; home Z
      var zTravel = move.axes[2].max - move.axes[2].min + 5 ; calculate how far Z can travel plus 5mm
      G1 H1 Z{var.zTravel} F600                             ; coarse home in the -Z direction
      G1 H2 Z5 F6000                                        ; move back 5mm
      G1 H1 Z-10 F300                                       ; fine home in the -Z direction
      G1 H0 Z130                                               ;move z down 10mm
      homey.g
      ; homey.g
      ; called to home the Y axis
      ; increase Z
      G1 H2 Z5 ; move Z relative to current position to avoid dragging nozzle over the bed
      ; home Y
      var maxTravel = move.axes[1].max - move.axes[1].min + 5 ; calculate how far Y can travel plus 5mm
      G1 H1 Y{-var.maxTravel} F6000 ; coarse home in the -Y direction
      G1 Y5 F7200 ; move back 5mm
      G1 H1 Y{-var.maxTravel} F300 ; fine home in the -Y direction
      ; decrease Z again
      G1 H2 Z-5 F7200 ; move Z relative to current position
      homez,g
      ; home Z
      var maxTravel = move.axes[2].max - move.axes[2].min + 5 ; calculate how far Z can travel plus 5mm
      G1 H1 Z{var.maxTravel} F1000                            ; coarse home in the +Z direction
      G1 Z-5 F6000                                            ; move back 5mm
      G1 H1 Z{var.maxTravel} F300                             ; fine home in the +Z direction
      G1 H0 Z130                                              ; move z down 10mm
      Thanks
        droftarts administrators @Alijambo73
        @Alijambo73 Currently there isn't a way to define a different endstop position for each driver in an axis, though there is a feature request to do this: https://github.com/Duet3D/RepRapFirmware/issues/627
        This means you have to do it the 'old fashioned' way, by splitting the axes. See the 'In RepRapFirmware 2.x' tab here: https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_auto_levelling#axis-levelling-using-endstops
        In that example, in the last step "Step 4: Edit your homez.g" you can add a move to square your axes. Note this refers to the Z axis, but can be any axis. eg:
        ; Move Z and U  down until the switches triggers
        G1 H1 Z-205 U-205 F1000
        ; Add move to square axis, can be Z or U
        G1 H2 U-1
        ; back to combined axes and hidden U
        M584 Z2:3 P3
        T3P3 created this issue in Duet3D/RepRapFirmware
        open Different endstop position for each driver in an axis #627
        Alijambo73undefined 1 Reply Last reply Reply Quote 0
          Alijambo73 @droftarts
          @droftarts Thanks for the reply. I treid this but I'm having endtop issues.
          If I have the drivers set like this:
          ; Smart Drivers
          M569 P0.3 S1 D2 ; driver 0.3 goes forwards (U or Y2 axis)
          and Axis like this:
          If I have my enstops configured like this:
          Then the U and V don't work. I can see them triggering correctly in the endsop monitor for U and V axis but when they are triggered during homeing they don't stop the motor when triggered.
          So I tried this:
          M574 X1 S1 P"io1.in" ; configure X axis endstop via pin io1.in
          M574 Y1 S1 P"io2.in+io3.in" ; configure active-high endstop for low end on Y via pin io2.in + io3.in
          M574 Z2 S1 P"io4.in+io5.in" ; configure active-high endstop for high end on Z via pin io4.in + io5.in"
          But then they work they are combined on the same axis but I get "Error: Failed to enable endstops"
          code; homey.g
          ; increase Z
          ; home Y
          ; decrease Z again
          M584 Z0.1 U0.3 P5                                       ; split Z motor control to Z and V and show U (param P5) in the UI
          G1 H1 Z-205 U-205 F1000                                   ; Move Z and V down until the switches triggers
          G1 H2 U3.175                                           ; Add move to square axis, can be Z or U
          M584 Z0.2:0.4 P3                                        ; back to combined axes and hidden U_text
          ; home Z
          M584 Z0.2 V0.4 P5                                       ; split Z motor control to Z and V and show V (param P5) in the UI
          G1 H1 Z205 V205 F1000                                   ; Move Z and V down until the switches triggers
          G1 H2 V-1.014                                           ; Add move to square axis, can be Z or V
          M584 Z0.2:0.4 P3                                        ; back to combined axes and hidden V
          How should the end stops be configured and are the homez.g and homey.g seup correctly?
          Thanks
            @Alijambo73 Note: your homey.g is wrong. When you split the axis, you have put Z in. You want Y and U, not Z and U. I'm basing the example below on homez.g.
            Your endstops can be configured where and when they are needed; they don't have to be defined only in config.g and then not defined again. Also, you don't need to re-home the Z and U axes after you have homed them as a combined Z, you just need to give U it's position with G92, then apply the adjustment. So there's a few ways to do this.
            Probably easiest is to keep the config.g as:
            Then home Z normally. After that, change the last section of homez.g to:
            G92 V130          ; Set V axis to the same as the Z axis
            G92 V130          ; Probably easiest to set V back to the same value as the Z axis
            For Y, make sure you use the correct axis labels! so something like:
            M584 Y0.1 U0.3 P5 ; split Y motor control to Y and U and show U (param P5) in the UI
            G92 U0            ; Set U axis to the same as the Y axis
            G1 H2 U3.175      ; Add move to square axis, can be Y or U
            G92 U0            ; Probably easiest to set U back to the same value as the Y axis
            I haven't tested this, so use with caution!
              @droftarts Thanks. I actually just got it working in a similar way. I probably have a few extra steps but here is what I have as of now.
               home Z
              ;G90                                                     ; absolute positioning
              ;G1 H0 Z130                                              ; move z down 10mm
              G1 H1 Z140 V140 F500                                    ; Move Z and V down until the switches triggers
              G92 V0
              G1 H0 V-2.184 F1                                      ; Add move to square axis, can be Z or V
              G92 V140
              G1 H0 Z130 F1000                                             ; move z down 10mm
              and
               homey.g
              ; increase Z
              ; home Y
              ; decrease Z again
              M584 Y0.1 U0.3 P5                                       ; split Y motor control to Y and V and show U (param P5) in the UI
              G1 H1 Y-205 U-205 F1000                                   ; Move Y and U down until the switches triggers
              ;G92 Y0
              G1 H0 Y5.175 F100                                          ; Add move to square axis, can be Y or U
              G92 Y0
              M584 Y0.1:0.3 P3                                        ; back to combined axes and hidden U
              G90
              I think I will leave it as is for now unless you see anything that will cause me problems.
              Can I just add the additions to the end of my home all file?
              Thank you for the help.
                @Alijambo73 How did you define the endstops? Because you're homing Z once together, then individually (same for Y). Usually you would need to redefine the endstops between them, or you get the "Error: Failed to enable endstops" message, eg have this at the beginning of homez.g
                then when you split the axes, redefine as:
                It takes a few less homing movements if you do it the way I suggested.
                Alijambo73undefined 2 Replies Last reply Reply Quote 0
                  @droftarts So I changed my config.g to this
                  and my homez to this
                  ; home Z
                  ;var maxTravel = move.axes[2].max - move.axes[2].min + 5 ; calculate how far Z can travel plus 5mm
                  ;G1 H1 Z{var.maxTravel} F1000                            ; coarse home in the +Z direction
                  ;G1 Z-5 F6000                                            ; move back 5mm
                  ;G1 H1 Z{var.maxTravel} F300                             ; fine home in the +Z direction
                  ; level Z
                  M547 Z2 S1 P"io4.in"
                  M547 V2 S1 P"io5.in"
                  G92 V0                                                  ; set V to 140
                  G1 H0 V-1.7 F1                                        ; Add move to square axis, can be Z or V
                  G92 Z140 V140                                                ; set V to 140
                  This leads to "Warning: M547: Command is not supported" and "Error: in file macro line 15: G1: Failed to enable endstops"
                  in the link https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_auto_levelling#axis-levelling-using-endstops It has the endstops configured one per axis and doesn't reference them at all in the home z example. My U and V endstops were not triggering the corresponding drivers to stop so changing the config g solved that.
                  Let me know if you can see what I'm missing with the endstops in my home z file.
                  Thanks
                    @droftarts As of now this is what I have in my config.g
                    and in my homez.g
                    ; home Z
                    ; level Z
                    After reading a little closer i realized i miss the point of adding M574 Z2 S1 P"io4.in+io5.in" in the begining of homez.g. I still get the error "Failed to enable endstops" error.
                      Phaedrux Moderator @Alijambo73
                      @Alijambo73 said in Dual Motor Auto Square and Leveling:
                      You have M547 instead of 574
                        Alijambo73 @Phaedrux
                        @Phaedrux Wow, I can't believe I missed that. Everything seems to be working perfectly now.
                        Thank you for all the help.
