Bug / Issue : DCS has been stopped
I just experienced a mid-print failure associated with the message:
"Connection interrupted, attempting to reconnect...
DCS has been stopped"My print was ~30% complete when this occurred, but the printer state was as if the print completed successfully: on the Job > Status page it had the option for Print Again, and the heaters were turned off. I checked the GCODE file and it looks fine, i.e. there is a full file worth of GCODE.
For context, I am running:
- Duet 3 MB6HC on SBC mode with Raspberry Pi 5
- Duet 3 Expansion Board 3HC
- Version 3.5.3 (stable) for each of the DWC, DSF, and MB6HC & EXP3HC boards
There is another thread from 4 years ago with the same issue but it seems it was marked as resolved with a new firmware revision.
I am now trying the print again now to see if I can replicate the behavior.
@chrismbp Whenever you get an unexpected crash, please make sure to run M122 as soon as possible, and post the response. This usually can give valuable troubleshooting info. As you're using SBC, the system log may also be useful. Without these, it's difficult to know what might have happened.
