    Closed-loop with Stepper online encoder and 1HCL expansion?
    closed loop 1hcl magnetic encoder stepper online
    • Forum-userundefined
      Forum-user
      Hi all,
      Is it possible to run in a closed loop configuration using the magnetic encoder built into the Stepperonline motors with the 1HCL board?
      Here's a link to the specific motor - [https://www.omc-stepperonline.com/nema-17-closed-loop-stepper-motor-16ncm-22-7oz-in-with-magnetic-encoder-1000ppr-4000cpr-17hs08-1004-me1k](link url)
      I would like to drive the motor with the 6HC without using the external CL42T driver specified, however I'm unsure if the two are directly compatible. Has anyone had any luck in getting it working?
      I have a Duet magnetic encoder on other motors which I find works well, but this is needed for a very tight spot.
      Thanks
      Forum-userundefined droftartsundefined 2 Replies Last reply Reply Quote 0
        Forum-user @Forum-user
        @Forum-user guessing it would have to go to the quadrature input as its not digital for SPI?
          droftarts administrators @Forum-user
          @Forum-user It looks like the encoder output of that motor is the same as is normally expected from a Quadrature encoder, despite calling itself a 'magnetic encoder'. I guess this makes it more compatible with existing drivers. This should be supported using the quadrature input on the 1HCL. See https://docs.duet3d.com/Duet3D_hardware/Duet_3_family/Duet_3_Expansion_1HCL#quadrature-encoder
          Forum-userundefined 2 Replies Last reply Reply Quote 1
            Forum-user @droftarts
            @droftarts Seems to be working out of the box with the quadrature input
            • Forum-userundefined Forum-user marked this topic as a question
            • Forum-userundefined Forum-user has marked this topic as solved
              @droftarts Here's another closed-loop add on board I'm looking it (testing a couple of different options). Not much info on this board, could it be wired as a single ended driver connection with step -, dir-, en- on the 1XD going to EN, Stp, Dir? Attached a picture with the pin outs - IMG_7285.jpg
                @Forum-user Looks like a MKS SERVO42C V1 board. See https://github.com/makerbase-mks/MKS-SERVO42C/wiki/MKS-SERVO42C-V1.0-Home
                I'll have a look tomorrow how it can be wired. I'd guess you need to use the on-board interface to set the mode, covered here https://github.com/makerbase-mks/MKS-SERVO42C/wiki/Menu-instruction-V1.0
