    Duplicate heaters after print complete or cancelled.
    Duet Web Control
    • gw3d3undefined
      gw3d3
      Hey all, I've been trying to set my machine up so that the dryer will stay on at the requested temperature after a print. I believe in attempting to do so I caused this issue, but I'm unsure of the best way forward here. Cancel Heater duplicate.png
      All the functionality is still there and it goes away with a power cycle.
      I use Cura as a slicer. Here is the end G code:
      ;Retract the filament and move tool head away.
      G92 E1
      G1 E-0.5 F300 ; Retract filament 0.5mm
      G28 XY ; Move tool head to home position
      M84 ; Disable stepper motors
      M0 ; Triggers stop.g in Duet system files
      Stop.g:
      ;stop.g
      M104 T0 S0 ;Turn off hotend
      M140 H1 S0 ;Turn off heated bed
      M141 H2 S0 ;Turn off printer chamber heater
      Thank you all in advance for any insight!
        droftarts administrators @gw3d3
        @gw3d3 M140 and M141 with an H parameter create a heater. Use the P parameter if you have more than one bed or chamber, otherwise leave out the H parameter. See https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m140-set-bed-temperature-fast-or-configure-bed-heater
        ie this is sufficient:
        M140 S0 ;Turn off heated bed
        M141 S0 ;Turn off printer chamber heater
        gw3d3undefined 2 Replies Last reply Reply Quote 0
        • gw3d3undefined
          gw3d3 @droftarts
          @droftarts Thank you! I will try this with a short print and post results!
          • gw3d3undefined
            gw3d3 @droftarts
            This post is deleted!
            • gw3d3undefined
              gw3d3
              This worked, Thank you!
              • droftartsundefined droftarts marked this topic as a question
              • droftartsundefined droftarts has marked this topic as solved
