    I don't understand why this is happening
    55
    3721
    • TimVukman
      TimVukman last edited by
      Hi:
      I am trying to set up my first delta printer, and I'd appreciate a nudge in the right direction to address an issue.
      I can use G91, and then G1 (xyz)number to move each pair of arms up and down properly, and confirm that each one moves in the correct direction.
      I can then run G28 and the printer will home and change the status of the end stop switch while stopping the arms.
      If I try to run the bed level script from the main screen, or if I issue a G29, the carriage starts moving up and making a horrible noise as arm holder hammers against the end stop (Z first)
      If all the movements are correct in the manual mode, why does it move the opposite way with G29?
      Thanks
      Tim
      • TimVukman
        Hi:
        Upgraded firmware to 1.20 with no problems. Issue reported above unchanged.
        • timcurtis67
          timcurtis67 last edited by
          What is written in your homeall.g file? Can you home without issues?
            1. Check whether you have any default deployprobe.g and retractprobe.g files in /sys on the SD card. If you have and you didn't write them yourself, delete them. You can do this in the Settings/System Editor page of DWC.
            2. If that doesn't fix it, please share your config.g file.
            • TimVukman
              Hi:
              Thanks so much for getting back to me. I do not have either deploy or retract probe files on the SD card.
              My Config.g file is```
              ; Configuration file for Duet WiFi (firmware version 1.17 to 1.19)
              ; generated by RepRapFirmware Configuration Tool on Sun Jan 07 2018 13:38:34 GMT-0500 (Eastern Standard Time)
              M111 S0 ; Debugging off
              G21 ; Work in millimetres
              ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration.
              M665 R85 L218 B85 H300 ; Set delta radius, diagonal rod length, printable radius and homed height
              M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them
              M208 Z-0.7 S1 ; Set minimum Z
              M574 X2 Y2 Z2 S0 ; Set active low endstops
              M558 P4 X0 Y0 Z0 H10 F120 T2400 ; Set Z probe type to switch, the axes for which it is used and the dive height + speeds
              G31 P600 X11 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
              M557 R85 S20 ; Define mesh grid
              M350 X16 Y16 Z16 E16 I0 ; Configure microstepping without interpolation
              M92 X80 Y80 Z80 E663 ; Set steps per mm
              M566 X1200 Y1200 Z1200 E1200 ; Set maximum instantaneous speed changes (mm/min)
              M203 X18000 Y18000 Z18000 E1200 ; Set maximum speeds (mm/min)
              M201 X1000 Y1000 Z1000 E1000 ; Set accelerations (mm/s^2)
              M906 X1000 Y1000 Z1000 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
              M84 S30 ; Set idle timeout
              M305 P0 T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heater 0
              M305 P1 T100000 B4388 C0 R4700 ; Set thermistor + ADC parameters for heater 1
              M563 P0 D0 H1 ; Define tool 0
              M550 PFLSUN ; Set machine name
              M552 S1 ; Enable network
              M587 S"BELL137" P"xxxxxxxx" I192.168.1.21 J192.168.1.254 K255.255.255.0 ; Configure access point and IP addresses. You can delete this line once connected
              M586 P0 S1 ; Enable HTTP
              M586 P1 S0 ; Disable FTP
              M586 P2 S0 ; Disable Telnet
              M106 P1 S0 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
              T0 ; Select first tool
              and my homedelta.g file is
              [[language]]
              ; homedelta.g
              G91 ; relative positioning
              ;*** Slow homing has been configured. Change F240 to F2400 below when your configuration is working
              G1 S1 X311.5 Y311.5 Z311.5 F240 ; move all towers to the high end stopping at the endstops (first pass)
              G1 X-5 Y-5 Z-5 F2400 S2 ; go down a few mm
              G1 S1 X10 Y10 Z10 F240 ; move all towers up once more (second pass)
              G1 Z-5 F2400 ; move down a few mm so that the nozzle can be centred
              G90 ; absolute positioning
              G1 X0 Y0 F2400 ; move X+Y to the centre
              Thanks,
              Tim
              • TimVukman
                Home (G28) works just fine. If I try to move any axis with the duet control software or pronterface, if I input a - number, my carriages go UP. They will go down if I enter a positive number, but only until the number matches what has been entered as the max height for the machine. I is actually 306.5.
                I would have thought that Z should go to 0 when I home the machine (like my cartesian)
                I am using the Duet from my Cartesian at the moment in this delta. I have another DuetWifi on it's way, but I am not sure when it will arrive.
                I like the DuetWifi so much that it will be used in both my printers and maybe a laser cnc if I get one built.
                • clearlynotstefan
                  clearlynotstefan last edited by
                  Post your bed.g please
                    Delta printers home to the top.
                    What happens if you use the Z jog buttons in DWC to jog the Z axis in the negative direction? It should move the effector toward the bed. After you have moved the effector down sufficiently, you can jog X and Y. You can't jog X and Y when the effector is right at the top.
                    • TimVukman
                      Jogging Z by -10 won't execute because it wants to go up and it is homed so there is nowhere to go.
                      Bed.g
                      [[language]]
                      ; bed.g
                      ; called to perform automatic delta calibration via G32
                      ; Probe the bed at 6 peripheral and 3 halfway points, and perform 6-factor auto compensation
                      ; Before running this, you should have set up your Z-probe trigger height to suit your build, in the G31 command in config.g.
                      G30 P0 X0 Y84.2 H0 Z-99999
                      G30 P1 X66.01 Y38.11 H0 Z-99999
                      G30 P2 X66.01 Y-38.11 H0 Z-99999
                      G30 P3 X0 Y-84.2 H0 Z-99999
                      G30 P4 X-73.61 Y-42.5 H0 Z-99999
                      G30 P5 X-73.61 Y42.5 H0 Z-99999
                      G30 P6 X0 Y41.05 H0 Z-99999
                      G30 P7 X29.84 Y-17.23 H0 Z-99999
                      G30 P8 X-36.81 Y-21.25 H0 Z-99999
                      G30 P9 X0 Y0 H0 Z-99999 S6
                      ; Use S-1 for measurements only, without calculations. Use S4 for endstop heights and Z-height only. Use S6 for full 6 factors
                      ; If your Z probe has significantly different trigger heights depending on XY position, adjust the H parameters in the G30 commands accordingly. The value of each H parameter should be (trigger height at that XY position) - (trigger height at centre of bed)
                        Jogging Z by -10 should move the effector down, not up. Are you sure that you have the carriages moving in the right direction? After sending G91, sending G1 S2 X10 should move the X carriage up 10mm, and G1 S2 Y-10 should move the X carriage down 10mm. Similarly for the Y and Z carriages.
                        • TimVukman
                          Hi and thanks for staying on this with me.
                          From Pronterface
                          I have issued a G28 and the carriages are all up at the top with the limit switches tripped.
                          M114 returns X:0.00 Y:0.00 Z:295.004
                          M119 returns Endstops -X: not stopped Y: not stopped, Z: not stopped, Z probe: at min stop
                          From DWC
                          G1 S2 Y-10 moves Y up
                          G1 S2 Y+10 moves Y down 10
                          G1 S2 X-10 moves X up 10
                          G1 S2 X+10 moves X down 10
                          G1 S2 Z-10 moves Z up 10
                          G1 S2 Z+10 moves Z down 10
                          Wiring between Wifi port and Stepper Motor is verified that what I think is X is what is connected to X port
                          Right Front Vertical Extruded Axis is X
                          Left Front Vertical Extruded Axis is Y (1 Step Clockwise around Axis from X)
                          Read Extruded Axis is Z (2 Steps Clockwise around Axis from X). (1 Step CounterClockwise)
                          Homeall from DWC moved X and Z up to engage limit switches (were only 10 or so away)
                          Homeall did not move Y all the way to limit switch. Moved up what looks like 10
                          Limit Switches match Axis designations.
                          All switches Black wire on GND on Board - Outside pin on actual switch
                          All switches Red wire on STP on Board - Opposite Outside pin on actual switch
                          Tim
                            1. Your motors are all moving in reverse. Correct them by changing S0 to S1 or vice versa in your M569 P0, P1 and P2 commands.
                            2. It sounds that you are using the NC endstop switch contacts. The endstop LEDs on the Duet will be lit when the switches are not triggered, and off when they are triggered. This means that in your M574 command you need S1 not S0.
                            • TimVukman
                              Hi
                              Well, that would explain why I was having so much trouble setting it up.
                              I switched all the motors and M574
                              Homeall worked, but all carriages bounced out of closed
                              I tried to do the auto bed leveling and the hotend stopped about 50mm above the heat bed. There is a limit switch in the hot end that opens when the nozzle touches the bed. Should that one be S1?
                              • TimVukman
                                M574 has only three endstops listed. Should I add another for the hot end endstop? It is wired to the E0 port beside X limit switch
                                  There is no hot end endstop, but you may have a Z probe. It is configured using M558, not M574.
                                  If the hot end stops above the bed when you try to run auto calibration, that suggests that that least the H parameter in your M665 command is a long way out. See https://duet3d.com/wiki/Calibrating_a_delta_printer#Setting_up_your_initial_delta_parameters.
                                  • TimVukman
                                    Ok Z Probe certainly covers the way it operates and the function it carries.
                                    Thanks. I should be able to move on with the Calibration link
                                    Tim
                                    • TimVukman
                                      Hi:
                                      When I click the auto bed level, the effecter will drop to about 40mm away from the bed and go through the motions.
                                      I get a message saying that the Z probe has already been triggered which it will be since it is closed on the print head.
                                      Does it stop at that height because it is already closed?
                                      Do I have to rewire the probe? It is set to open when the probe touches the bed.
                                      • TimVukman
                                        Sorry
                                        My Bad.
                                        Missed the M564 S0 in configuring the Z Probe
                                        • TimVukman
                                          Ok
                                          I was able to get down to the bed and determine the trigger height on the Z probe which is 0.2 It is repeatable.
                                          I did an M500 to save this information.
                                          If I home from the bed, the effector will stop before the endstops are reached. If I home again, it will home properly
                                          If I initiate the autobed level, the effector will stop and complete it's various points around the bed while it is still 72mm above the bed. At each probe point, it will report that the Z Probe is already triggered.
                                          I am obviously still missing (not grasping) something in this process.
                                          Thanks
                                          Tim
                                          Config.g
                                          [[language]]
                                          G90                                                             ; Send absolute coordinates...
                                          M83                                                             ; ...but relative extruder moves
                                          M665 R85 L218 B85 H306.5                                        ; Set delta radius, diagonal rod length, printable radius and homed height
                                          M208 Z-0.7 S0                                                   ; Set minimum Z
                                          M574 X2 Y2 Z2 S1                                                ; Set active low endstops
                                          G31 P600 X11 Y0 Z0.2                                            ; Set Z probe trigger value, offset and trigger height
                                          M569 P0 S0                                                      ; Drive 0 goes forwards
                                          M569 P1 S0                                                      ; Drive 1 goes forwards
                                          M569 P2 S0                                                      ; Drive 2 goes forwards
                                          M569 P3 S1                                                      ; Drive 3 goes forwards
                                          Bed.g
                                          [[language]]
                                          ; bed.g
                                            @TimVukman:
                                            #5 at https://duet3d.com/wiki/Common_problems_and_their_solutions.
                                            @TimVukman:
                                            Test your Z probe. For a switch type Z probe, the Z probe reading in DWC should be 1000 when the probe is triggered, and 0 when it is not. If yours is the other way round, then if possible use the NC switch contacts instead of the NO contacts. If you can't do that, add I1 to your M558 command.
                                            • TimVukman
                                              Thanks very much. I will follow through on #5
                                              Changing the M558 should be straight forward. I read 1000
                                              I have a bigger problem however. My new DuetWifi Card arrived today and the setup was going along just fine until I tried to connect both printers at the same time. They started off with one connecting, and when I went through the part that calls for Y A Terminal, it took the information, but when I rebooted, it would not connect. Now my other one sn't connecting either and neith is showing on Angry IP Scanner.
                                              I will try one at a time via the USB direct. Did I read a caution somewhere that said there was something I had to do before I added a second card on the network. Something other than a different IP?
                                              Thanks
                                              Tim
                                                The note about having more than one Duet on the network only applies to using the Duet 06 or 085, or the Duet Ethernet with firmware older then 1.19. You had to configure them to use different MAC addresses.
                                                • TimVukman
                                                  Is there a workaround for not being able to read the SD card on the DuetWifi? My new board that arrived yesterday is giving me an "error 1 accessing SD card" message when I try to read the card from the DuetWifi board using the DuetDisplay.
                                                  The message at the top of the display screen says Files on card 1 <_>
                                                  I can read / write / copy etc to the little card when it is inserted in an adapter on my PC
                                                  • TimVukman
                                                    I seem to have recovered the original DuetWifi. I will go after the step #5 that you identified above.
                                                    • TimVukman
                                                      To be clear, my new DuetWifi is installed in the original cartesian printer and is unable to read the SD card.
                                                      My original DuetWifi is installed in my new Delta which is my original reason for seeking help
                                                      Thanks
                                                      Tim
