    Movement distances are wrong…
    • peirofundefined
      peirof
      new of this morning….
      With Duet Web interface, i have this issue, a commit a comand for move z-100, and really moves aprox 200 mm down.
      Why? How adjust this?
      Yesterday i had do a print, and works ok...
      • peirofundefined
        peirof
        one thing….
        Yesterday change microstepping in config.g, because i installed Nimble extruder,...
        [[language]]
        M350 X16 Y16 Z16 E16 I1 ; Configure microstepping with interpolatio
        M92 X160 Y160 Z160 E2470 ; Set steps per mm
        M566 X600 Y600 Z600 E40 ; Set maximum instantaneous speed changes (mm/min)
        M203 X12000 Y12000 Z12000 E3000 ; Set maximum speeds (mm/min)
        M201 X600 Y600 Z600 E1500 ; Set accelerations (mm/s^2)
        M906 X1200 Y1200 Z1200 E7200 I30 ; Set motor currents (mA) and motor idle factor in per cent
        M84 S30 ; Set idle timeou
        i suppose this have realtion….
          Changing microstepping changes the steps/mm. See the text starting "When M350 is processed…" at https://duet3d.com/wiki/G-code#M350:_Set_microstepping_mode.
          • peirofundefined
            peirof
            i have find it
            this line is wrong
            [[language]]
            for Nimble interpolation its only in extruder, not in axes
            this is ok, think
            [[language]]
            M350 X32 Y32 Z32 E16 I1 ; Configure microstepping with interpolatio
            • Dougal1957undefined
              Dougal1957
              Pierof all you need to do is change your M92 line to
              M92 X80 Y80 Z80 E2470
              That will fix your issue
              Doug
              remember you are using 1.8 degree motors and 20 tooth pulleys
