BTT smart filament semsor V2
I'd like to install a BTT smart filament sensor V2. It has two separate outputs for the rotating device and the presence switch.
How do i have to install / setup this sensor?
Can i map two inputs for one sensor in config.g? That does't seems to be the case when i read the docu... -
@cosmowave RRF only supports one of those two at a time. Best raise a feature request
@jay_s_uk Thanks for the info.
I have wired the motion sensors to endstop connectors of the Duet2 board. Additionally i've wired the presence switch to gpin ports of the duex board.Are the drive numbers defined with the M591 command limitted?
After running config, the following warning appears:
Error in start-up file macro line 139: in file macro line 139: M591: parameter 'D' too highIt's a e3d motion system/toolchanger with Duet2+Duex5, running RRF3.5.3
config.g; Configuration file for Duet WiFi / Ethernet running RRF3 on E3D Tool Changer ; executed by the firmware on start-up ; ; General preferences G21 ; Work in millimetres G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Toolchanger" ; set printer name M669 K1 ; Select CoreXY mode ; Network M552 P192.168.0.44 S1 ; enable network and set static ip M553 P255.255.255.0 ; set network mask M554 P192.168.0.1 ; gateaway M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S1 ; enable Telnet for connection with RepetierServer ; Drive direction M569 P0 S0 ; Drive 0 X M569 P1 S0 ; Drive 1 Y M569 P2 S1 ; Drive 2 Z M569 P3 S0 ; Drive 3 E0 M569 P4 S0 ; Drive 4 E1 M569 P5 S0 ; Drive 5 E2 M569 P6 S0 ; Drive 6 E3 M569 P7 S0 ; Drive 7 COUPLER ;M569 P8 S0 ; Drive 8 UNUSED ;M569 P9 S0 ; Drive 9 UNUSED M584 X0 Y1 Z2 C7 E3:4:5:6 ; Apply custom drive mapping M208 X-35:328.5 Y-49:243 Z0:300 C-45:360 ; Set axis maxima & minima M92 X100 Y100 Z800 C91.022 E388:388:388:388 ; Set steps per mm assuming x16 microstepping M350 E16:16:16:16 I1 ; Configure microstepping with interpolation M350 C16 I10 ; Configure microstepping without interpolation M350 X16 Y16 Z16 I1 ; Configure microstepping with interpolation ;M566 X400 Y400 Z8 C2 E2:2:2:2 ; Set maximum instantaneous speed changes (mm/min) M566 X200 Y200 Z8 C2 E200:200:200:200 ; Set maximum instantaneous speed changes (mm/min) M203 X10000 Y10000 Z1200 C10000 E5000:5000:5000:5000 ; Set maximum speeds (mm/min) ;M201 X6000 Y6000 Z400 C500 E2500:2500:2500:2500 ; Set accelerations (mm/s^2) M201 X3000 Y3000 Z400 C500 E2500:2500:2500:2500 ; Set accelerations (mm/s^2) M906 X1800 Y1800 Z1330 I30 ; Idle motion motors to 30% M906 E1000:1000:1000:1000 C500 I10 ; Idle extruder motors to 10% ; Endstops M574 X1 Y1 S3 ; Set X / Y endstop stall detection M574 C0 Z0 ; C Z endstop ; Z probe M558 P8 C"zstop" H3 F360 I0 T20000 ; Set Z probe type to switch, the axes for which it is used and the dive height + speeds G31 P200 X0 Y0 Z0 ; Set Z probe trigger value, offset and trigger height M557 X10:290 Y20:180 S40 ; Define mesh grid ;Stall Detection M915 X Y S3 F0 H400 R0 ; X / Y Axes ; Heaters M308 S0 P"bedtemp" Y"thermistor" A"Bed" T100000 B4138 C0 ; Set thermistor M950 H0 C"bedheat" T0 ; Bed heater M143 H0 S225 ; Set temperature limit for heater 0 to 225C M140 H0 ; Bed heater is heater 0 M308 S1 P"e0temp" Y"thermistor" A"T0" T100000 B4725 C7.06e-8 ; Set thermistor M950 H1 C"e0heat" T1 ; Extruder 0 heater M143 H1 S305 ; Set temperature limit for heater 1 to 300C M308 S2 P"e1temp" Y"thermistor" A"T1" T100000 B4725 C7.06e-8 ; Set thermistor M950 H2 C"e1heat" T2 ; Extruder 0 heater M143 H2 S305 ; Set temperature limit for heater 2 to 300C M308 S3 P"e2temp" Y"thermistor" A"T2" T100000 B4725 C7.06e-8 ; Set thermistor M950 H3 C"duex.e2heat" T3 ; Extruder 0 heater M143 H3 S305 ; Set temperature limit for heater 3 to 300C M308 S4 P"e3temp" Y"thermistor" A"T3" T100000 B4725 C7.06e-8 ; Set thermistor M950 H4 C"duex.e3heat" T4 ; Extruder 0 heater M143 H4 S305 ; Set temperature limit for heater 4 to 300C ; Tools M563 P0 S"T0" D0 H1 F2 ; Define tool 0 G10 P0 X0 Y0 Z0 ; Reset tool 0 axis offsets G10 P0 R0 S0 ; Reset initial tool 0 active and standby temperatures to 0C M563 P1 S"T1" D1 H2 F4 ; Define tool 1 G10 P1 X0 Y0 Z0 ; Reset tool 1 axis offsets G10 P1 R0 S0 ; Reset initial tool 1 active and standby temperatures to 0C M563 P2 S"T2" D2 H3 F6 ; Define tool 2 G10 P2 X0 Y0 Z0 ; Reset tool 2 axis offsets G10 P2 R0 S0 ; Reset initial tool 2 active and standby temperatures to 0C M563 P3 S"T3" D3 H4 F8 ; Define tool 3 G10 P3 X0 Y0 Z0 ; Reset tool 3 axis offsets G10 P3 R0 S0 ; Reset initial tool 3 active and standby temperatures to 0C ; Fans M950 F1 C"fan1" M950 F2 C"fan2" M950 F3 C"duex.fan3" M950 F4 C"duex.fan4" M950 F5 C"duex.fan5" M950 F6 C"duex.fan6" M950 F7 C"duex.fan7" M950 F8 C"duex.fan8" M106 P1 S255 H1 T70 ; T0 HE M106 P2 S0 C"T0cooler" ; T0 PCF M106 P3 S255 H2 T70 ; T1 HE M106 P4 S0 C"T1cooler" ; T1 PCF M106 P5 S255 H3 T70 ; T2 HE M106 P6 S0 C"T2cooler" ; T2 PCF M106 P7 S255 H4 T70 ; T3 HE M106 P8 S0 C"T3cooler" ; T3 PCF ;tool offsets ; !ESTIMATED! offsets for: ; V6-tool: X-9 Y39 Z-5 ; Volcano-tool: X-9 Y39 Z-13.5 ; Hemera-tool: X20 Y43.5 Z-6 G10 P0 X25 Y43.5 Z-5.2 ; T0 G10 P1 X24.8 Y43 Z-4.85 ; T1 G10 P2 X24.95 Y43.2 Z-5.3 ; T2 G10 P3 X24.9 Y43.4 Z-5.48 ; T3 ;tool detection switches M950 J0 C"!duex.e2stop" ; Input 0 (T0 in dock) uses duex.e2stop, pullup enabled M950 J1 C"!duex.e3stop" ; Input 1 (T1 in dock) uses duex.e3stop, pullup enabled M950 J2 C"!duex.e4stop" ; Input 2 (T2 in dock) uses duex.e4stop, pullup enabled M950 J3 C"!duex.e5stop" ; Input 3 (T3 in dock) uses duex.e5stop, pullup M950 J4 C"!duex.e6stop" ; Input 4 (active Tool docked) uses duex.e6stop, pullup enabled ;filament detection ;T0 M591 D3 P7 C"e0stop" R80:120 L2.88 S1 ; pulse-generating sensor connected to E0 endstop for drive 3, allow 80-120% M950 J5 C"duex.gp1" ; define filament presence switch for T0 as input5 ;T1 M591 D4 P7 C"e1stop" R80:120 L2.88 S1 ; pulse-generating sensor connected to E0 endstop for drive 4, allow 80-120% M950 J6 C"duex.gp2" ; define filament presence switch for T1 as input6 ;T2 M591 D5 P7 C"xstop" R80:120 L2.88 S1 ; pulse-generating sensor connected to X endstop for drive 5, allow 80-120% M950 J7 C"duex.gp3" ; define filament presence switch for T2 as input7 ;T3 M591 D6 P7 C"ystop" R80:120 L2.88 S1 ; pulse-generating sensor connected to Y endstop for drive 6, allow 80-120% M950 J8 C"duex.gp4" ; define filament presence switch for T3 as input8 ;M572 D0 S0.03 ; pressure advance T0 for PLA ;M572 D1 S0.03 ; pressure advance T1 ;M572 D2 S0.03 ; pressure advance T2 ;M572 D3 S0.03 ; pressure advance T3 ;NeoPixel M950 E0 C"connlcd.5" T1 U8 M150 E0 P0 S8 M950 E1 C"connlcd.6" T1 U32 M150 E1 P0 S32 ;Miscellaneous M593 F42.2 ; cancel ringing at 42.2Hz (https://forum.e3d-online.com/threads/accelerometer-and-resonance-measurements-of-the-motion-system.3445/) M501 ; load config-override.g M575 P1 S1 B57600 ; Enable LCD G29 S2 ; disable mesh T-1 ; deselect tools -
@cosmowave you only have 4 extruders, 0 to 3. There is no D4 in your setup
@jay_s_uk Ok. Thanks.
I refered to the drives defined with M569...
