Duet not consistently running code
I have a bunch of code to automatically open/close a retractable cover on my printer and I have subsets of code that run different beeps to indicate motion and M291's to prompt the user. What I'm noticing is that it's not always running all of my code. I can't tell if line 10 isn't running b/c the motor is stopped with relay logic, lines 11 and 12 are definitely not running.
Problematic code
M98 P"soundNotifyShort.g" ; beep M42 P17 S1 ; set motor direction to closing G4 S0.25 ; short wait to let relay flip while sensors.gpIn[15].value == 1 ; while not fully closed yet M42 P16 S1 ; turn on motor G4 S4 ; wait M98 P"promptUser.g" ; give user opportunity to cancel if global.userPrompt == 1 break ; user canceled M42 P16 S0 ; turn off motor M98 P"soundAlert.g" ; beep - note this is apparently not running b/c I don't hear it beep M291 P"Top cover is at max closed" S2 ; this doesn't run either b/c I don't see the message box in DWC soundNotifyShort.g
M42 P20 S1 G4 S.37 M42 P20 S0 promptUser.g
; Working within the limitation of the firmware, for there to be a non-exiting default option you must have a Cancel button (J1) and a message box ; of S4 or above, so the options are redundant if you only want a yes or no value, which I do. So the logic is reversed, no response sets input = 0 ; creating a new global variable, and setting it to a non-zero value. So IF the user responds, the variable will change to 0 set global.userPrompt = 3 M291 P"Continue?" S4 T3 J1 K{"Yes", "No"} F0 set global.userPrompt = input ; global.userPrompt legend ; 0 is Yes ; 1 is No ; 3 is No response soundAlert.g
M42 P19 S1 G4 S2.2 M42 P19 S0 -
@p8blr SBC mode? Standalone? Firmware version?
@jay_s_uk SBC mode, 3.5.3-rc.1. I'm afraid to update because that was an ordeal last time that bricked some of my expansion boards updating in sbc mode.
This code runs every line
M98 P"soundNotifyShort.g" ; beep G4 S1 ; wait var myCounter1 = 5 while iterations <= 5 M98 P"promptUser.g" ; give user opportunity to cancel if global.userPrompt == 1 break G4 S1 M98 P"soundAlert.g" ; beep M291 P"end of code" S2 This code skips the lines after the while loop
M98 P"soundNotifyShort.g" ; beep M42 P17 S1 ; set closing direction G4 S1 ; wait while sensors.gpIn[15].value == 1 ; while not fully closed yet M42 P16 S1 ; turn on motor M98 P"promptUser.g" ; give user opportunity to cancel if global.userPrompt == 1 break G4 S1 M42 P16 S0 ; turn off motor M98 P"soundAlert.g" ; beep M291 "Top cover is at max closed" S2 -
@p8blr Try putting in an M400 after the while loop. RRF 3.5 made changes to how things run, due to multiple motion streams, and M400 causes everything to resynchronise. See https://docs.duet3d.com/en/User_manual/RepRapFirmware/Multiple_motion_systems.
Also, please update to 3.5.3. This might be resolved already. I doubt you'll have the issues when updating, 3.5.3 has been pretty stable. We don't support beta and rc releases once the main release has released.
@droftarts I updated to 3.5.3 and tested the code but no change, I then added a M400 like this below, and it still did not run the last few lines of code, line 11 & 12.
M98 P"soundNotifyShort.g" ; beep M42 P17 S1 ; set closing direction G4 S1 ; wait while sensors.gpIn[15].value == 1 ; while not fully closed yet M42 P16 S1 ; turn on motor M98 P"promptUser.g" ; give user opportunity to cancel if global.userPrompt == 1 break G4 S1 M400 M42 P16 S0 ; turn off motor M98 P"soundAlert.g" ; beep M291 "Top cover is at max closed" S2 -
@p8blr your promptuser.g file includes this M291 command:
If that message box times out then it will abort the macro that it occurs in and any containing macros. I suspect that is why the containing macro does not complete.
There is already a request for a feature to allow the behaviour on timeout to be changed.
@dc42 Interesting. Any idea on an estimated completion date on the feature request? Or maybe a workaround I could do instead? I want the user to be able to have a way out of a very long while loop.
Thanks.
@p8blr said in Duet not consistently running code:
See https://github.com/Duet3D/RepRapFirmware/issues/959
Scheduled for “after 3.6.0”.
