[3.6.0.Beta.1] Halted due to step timing error
HI all,
Simple error during a regular print about 20/25 minutes in
Error: Movement halted because a step timing error occurred (code 3). Please reset the controller. Error: Existing: start=1789869067 length=8828, new: start=1789876874, overlap=1021 time now=1789871627
M122 Report
m122# === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.6.0-beta.1 (2024-09-24 10:07:04) running on Duet WiFi 1.02 or later Board ID: 0JD2M-9F8TA-GJ4TD-6J1D6-3SD6P-16PG6 Used output buffers: 11 of 26 (24 max) === RTOS === Static ram: 23360 Dynamic ram: 66884 of which 0 recycled Never used RAM 11944, free system stack 100 words Tasks: NETWORK(2,ready,14.7%,181) HEAT(3,nWait 5,0.1%,307) Move(4,invalid,0.5%,266) MAIN(2,running,84.7%,713) IDLE(0,ready,0.0%,29), total 100.0% Owned mutexes: HTTP(MAIN) === Platform === Last reset 27:19:22 ago, cause: power up Last software reset at 2024-09-01 17:47, reason: User, Gcodes spinning, available RAM 30728, slot 0 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 MCU temperature: min 20.1, current 30.4, max 32.1 Supply voltage: min 24.5, current 24.9, max 25.5, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/1, heap memory allocated/used/recyclable 2048/816/768, gc cycles 0 Events: 0 queued, 0 completed Date/time: 2024-11-10 18:19:10 Slowest loop: 376.85ms; fastest: 0.11ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 9 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 44.5ms, write time 118.3ms, max retries 0 === Move === Segments created 662, maxWait 60410311ms, bed comp in use: mesh, height map offset 0.000, hiccups added 42 (1.25ms), max steps late 1, ebfmin 0.00, ebfmax 0.00 Pos req/act/dcf: 34135.00/33905/0.92 3194.00/2900/0.16 1881.00/1885/-0.81 no step interrupt scheduled Driver 0: standstill, SG min 0 Driver 1: standstill, SG min 0 Driver 2: standstill, SG min 0 Driver 3: standstill, SG min 0 Driver 4: standstill, SG min 0 Driver 5: Driver 6: Driver 7: Driver 8: Driver 9: Driver 10: Driver 11: === DDARing 0 === Scheduled moves 18362, completed 18332, LaErrors 0, Underruns [5, 0, 0] === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 0 is on, I-accum = 0.2 Heater 1 is on, I-accum = 0.5 === GCodes === Movement locks held by null HTTP is ready with "m122#" in state(s) 0 Telnet is idle in state(s) 0 File is doing "G1 X233.739 Y193.061" in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Q0 segments left 1 Code queue 0 is empty === Network === Slowest loop: 667.84ms; fastest: 0.00ms Responder states: HTTP(4) HTTP(0) HTTP(4) FTP(0) Telnet(0) HTTP sessions: 2 of 8 === WiFi === Interface state: active Module is connected to access point Failed messages: pending 0, notrdy 5, noresp 1 Firmware version 2.1.0 MAC address a4:e5:7c:03:da:81 Module reset reason: Hardware watchdog, Vcc 3.40, flash size 2097152, free heap 42392 WiFi IP address 192.168.1.197 Signal strength -52dBm, channel 6, mode 802.11n, reconnections 0 Clock register 00002002 Socket states: 3 5 3 0 0 0 0 0
(Along with these ones: https://forum.duet3d.com/search?in=posts&term=Halted+due+to+step+timing+error&matchWords=all)
@droftarts
Not to worry, just logging incase and of the information is helpful.
