    [3.5.3-SBC] Closed loop position recovery / rehoming
    • timschneiderundefined
      timschneider
      Hello, I am having the following issue with my closed-loop printer in an SBC configuration using CoreXY when a ‘position error’ occurs. I get a motor driver-warning event for each motor, 2 in total, and 1 driver-error event for each motor, again 2 in total, for a total of 4 events for a full crash.
      content of driver-warning.g
      ; driver warning - 51.0 : 1024 ,Driver 51.0 warning: position tolerance exceeded
      if param.B > 0 && param.D == 0 && param.P == 1024 && move.axes[0].homed == false && move.axes[1].homed == false
        M99 ; ignore warning when drives are not homed
      echo "driver warning - "^{param.B}^"."^{param.D}^" : "^{param.P}^" ,"^{param.S}
      if !exists(global.event_driver_stall)
        global event_driver_stall = true
      ; check if a printjob is running
      ; if it is a can connected driver in closed loop mode with error position tolerance exceeded (param.B > 0 && param.D == 0 && param.P == 1024)
      if job.file.fileName != null
          set global.event_driver_stall = true
          M25        ; pause print and rehome X and Y
          M207 Z{tools[0].retraction.zHop+0.2}                                ; raise z-hop 0.2mm to prevent further crashes
          M24        ; resume print
        else
          set global.event_driver_stall = false                               ; do not rehome while pausing
          G91        ; relative positioning
          G1 H2 Z0.5 F600                                                     ; lift Z relative to current position
          M568 P0 R0 S0 A0                                                    ; disable hotend
          M25        ; pause print
      content of driver-error.g
      ; driver-stall.g
      ; called to home x and y after stall detection
      ; driver error - 51.0 : 3072 ,Driver 51.0 error: failed to maintain position
      if param.B > 0 && param.D == 0 && param.P == 3072 && move.axes[0].homed == false && move.axes[1].homed == false
      echo "driver error - "^{param.B}^"."^{param.D}^" : "^{param.P}^" ,"^{param.S}
      ; if it is a can connected driver in closed loop mode with failed to maintain position (param.B > 0 && param.D == 0 && param.P == 3072)
        else
        M25        ; pause print
      I have already tried to check if the printer is in the ‘pausing’ or ‘paused’ state to prevent further pauses, but the events are deferred and the first event is processed completely, including the resume print, before the second is processed.
      if state.status == "paused" || state.status == "pausing" || state.status == "resuming"
        M99 ; ignore this event - it is already handled
      How can I cancle pending events? or what else should I do?
      timschneiderundefined 1 Reply Last reply Reply Quote 0
        timschneider @timschneider
        I came up with the following solution:
        ; driver-warning.g
            set global.resume_deferred = state.upTime + 5                        ; resume print after 5 seconds
          else
            M25        ; pause print
        ; driver-error.g
          set global.resume_deferred = 0 ; reset resume_deferred
          else
          M25        ; pause print
        content of daemon.g
        if exists(global.resume_deferred) && global.resume_deferred > 0 && global.resume_deferred < state.upTime
            M24 ; resume print
        The magic is done by the global.resume_deferred. It is set to state.upTime + 5 which means 5 second delay.
        The flow looks like the following
        driver-warning event -> check if it is already paused if so, exit else set resume_deferred
        driver-error event -> check if it is already paused, if so, reset resume_deferred to 0 to disable it and exit
        daemon.g -> Check whether the delay for resume_deferred has already passed, if so resume the print.
