    Duet 3 Mini 5+ with 1LC, extruder Heater always on
    • Adamfilipundefined
      Adamfilip
      I have Duet 3 Mini 5+ with 1LC
      I double checked wiring,,
      using Revo heater 24v.
      Connected to 1lC Out1. using GND and +Vout wires
      extruder Heater is always on
      not sure why.
      M308 S1 P"121.temp0" Y"thermistor" T100000 B4267  ; Configure sensor 1 as E3D Revo thermistor on temp0
      M950 H1 C"121.out1" T1                            ; Create heater 1 using temp sensor 1 and output 1
      M307 H1 B0 S0.00 R2.5 C150 D5.5                   ; Disable heater (S0.00), ensure no bang-bang, and tune values as needed
      M143 H1 S280                                      ; Set max temperature limit for heater 1
      M563 P0 D0 H1 F0                                  ; Define tool 0, assign extruder 0, link heater 1, assign fan 0
      M568 P0 S0 R0
        Phaedrux Moderator @Adamfilip
        @Adamfilip said in Duet 3 Mini 5+ with 1LC, extruder Heater always on:
        GND and +Vout wires
        GND is not the PWM pin, and not switchable. You've just connected the heater directly to the power source. Use +VOUT and out1.
        Actually, for the heater, you should be using out0, not out1.
        https://docs.duet3d.com/en/Duet3D_hardware/Duet_3_family/Duet_3_Toolboard_1LC#wiring-diagram
        Adamfilipundefined 1 Reply Last reply Reply Quote 1
          Adamfilip @Phaedrux
          @Phaedrux Thanks I corrected that and its working fine now. appreciate your help.
          now that I moved my Cold End Fan to Out2. its working alot slower then when it was using Out0
          perhaps I will just wire it up to main 24v feed instead
          Adamfilipundefined 1 Reply Last reply Reply Quote 0
            Adamfilip @Adamfilip
            @Adamfilip just realized i can add the jumper so the fan gets 24v
