    Possible bug on baby stepping reset
    • sverreb
      sverreb last edited by
      In my printer profile for PETG I am adding some z offset by using baby stepping:
      [[gcode]]
      G28 ;
      G29 S1 ; Load and activate detailed bed map
      G1 Y1.0 Z0.2 F1000.0 ; prepare to prime
      G92 E0 ; reset extrusion distance
      G1 X60.0 E9.0  F1000.0 ; priming
      G1 X100.0 E12.5  F1000.0 ; priming
      M290 S0.20 ; set baby stepping
      This works perfectly the first time, however if I make a second print (which uses the same starting script) I see the printer using 0.4mm baby stepping offset.
      The documentation states that homing should reset baby stepping but in my case it does not appear to do so.
      • SJI
        SJI last edited by
        I’ve noticed the same effect with firmware Build 1.20
          Thanks, I have this on my list to test.
          • Falc.be
            Falc.be last edited by
            Yep noticed this too
              I have a feeling that this behaviour was deliberately changed in firmware 1.20 because several users complained that babystepping wasn't remembered from one print to the next.
