    metacode rread-only variables
    Firmware wishlist
    365
    • GeneRisiundefined
      GeneRisi
      My suggestion is to be able to create "global" variables ( also would work for "var" ) that could be declared "read-only", meaning that only the assignment in the declaration of the variable would be valid and using "set" would be flagged as invalid. As I clean up my firmware for my multi-tool printer I am finding that some global variables are really global constants (like the docking positions of the tools) vs true variables (like the previous upTime a macro was called).
      The declaration syntax would up to the firmware team.
      Thanks!
      Gene
      cosmowaveundefined 1 Reply Last reply Reply Quote 0
      • cosmowaveundefined
        cosmowave @GeneRisi
        @GeneRisi Can you give me a usecase for this wish?
        I'm not sure if this is necessary? If you never use a "set" command in your meta code, the global will stay as it is....
        Mankati FSXT+, DeltaTowerV2, E3D MS/TC
          dc42 administrators @cosmowave
          @cosmowave said in metacode rread-only variables:
          I think that's the whole point of it, to prevent it from being changed.
          One way of doing this would be to introduce new commands "const global" and "const var" that behave like "global" and "var" but the value is not allowed to be changed. Or maybe "global const" could create a global constant and "const" by itself create a local constant.
          @GeneRisi feel free to create a Github feature request for this.
          OwenDundefined GeneRisiundefined 2 Replies Last reply Reply Quote 2
          • OwenDundefined
            OwenD @dc42
            @dc42 said in metacode rread-only variables:
            This is probably closest to convention with most languages.
            If it resulted in lower memory usage then I'd vote for it.
              dc42 administrators @OwenD
              @OwenD using 'const' wouldn't affect the memory usage.
              OwenDundefined 1 Reply Last reply Reply Quote 0
              • OwenDundefined
                OwenD @dc42
                Ah well.
                In that case I can dress in either direction.
                Can't hurt anyone and may help some.
                • GeneRisiundefined
                  GeneRisi @dc42
                  @dc42 The use case is that it would be nice to know if I have messed up when I make a script change. The past several days have been challenging because I implemented a second "pebble wiper" for the tool changer and realized that the variable declarations were scattered and the naming was inconsistent. I now have a defGlobalConstants.g and defGlobalVars.g that is called by config.g and some tool unique code is being reduced using indexing.
                  While I have your ear, I wish there was a way to check the gcode for syntax errors without actually doing anything. I don't know if this is what "simulation" is meant to do; if it is, I need to read up on it. Having macros fail during prints is a very slow way to debug.
                    dc42 administrators @GeneRisi
                    @GeneRisi feel free to create a feature request at https://github.com/Duet3D/RepRapFirmware/issues with a link to this thread in it.
