    Cura Start and End GCode?
    • Icthus
      Icthus last edited by
      I've searched and I can't seem to find anything relevant to this and it could be my simple ignorance to this (As I'm new to the Duet and reprap firmware) but I can't seem to find anyone using 'Suggested' gcode start and end code?
      Can I ask what all you lot out there are using in yours? I'm trying to work out what is needed and not needed now with my new setup.
      This is what I am using now as it was what I used on my old printer
      Start Code
      G21 ;metric values
      G90 ;absolute positioning
      M82 ;set extruder to absolute mode
      M107 ;start with the fan off
      G28
      End Code
      M104 S0 ; turn off extruder
      M140 S0 ; turn off bed
      G1 X0 Y200 F1000 ; prepare for part removal
      M107 ; Fan Off
      M84 ; disable motors
      I do get errors on start a print now but I'm not sure whats best to put in there? Should I do G29? As I have the mini IR sensor for auto leveling.
      I'm curious to see what everyone else does for theres
      Thanks
      Gareth
      • darookee
        darookee last edited by
        My Start-script (using slic3r) is this:
        M140 S[first_layer_bed_temperature] ; set bed temperature with
        ;M104 S[first_layer_temperature]         ; set extruder temperature tool selection
        M98 P/sys/before_print.g
        The commented out M104 is so that slic3r thinks it's setting the extruder temperature, when it's actually not.
        /sys/before_print.g looks like this:
        M80 	; turn PSU on
        T0      ; Select tool 0
        M116	; Wait for tools
        G32 	; call bed.g
        ; Purge line
        G1 Z0.2
        G1 Y2 X25 F15000        ; move out of build volume
        G1 X175.0 E24 F1200     ; finish purge line
        G4 P5000	        ; Wait to let the plastic cool a little
        G1 X100.0 Y100.0 F15000 ; Move to middle to rip plastic off tip
        G92 E0                  ; reset extruder position to 0
        and bed.g looks like this, so I probably could replace the G32 with G29 S1…
        ; Clear any bed transform
        M561
        ; Home all axes
        G28
        ; Grid compensation
        G29 S1
        What this all does is
        • Setting the bed temperature
        • Selecting the first tool (the printer only has one)
        • Waits for all the temperatures to be at the set point
        • loads the mesh compensation map
        • extrudes a bit of filament to the front of the bed
        • Icthus
          Thank you very much darookee, can I ask what setup you have as well?
          • burtoogle
            burtoogle last edited by
            My cura start/end scripts for a kossel delta (using relative extrusion mode) are:
            [[language]]
            G28 ; home all axes
            G1 X0 Y0 Z25 F8000 ; descend
            and
            [[language]]
            M83 ; extruder relative mode
            G1 E-2 F2000 ; retract
            M106 S0 ; turn off fan
            G28 ; home
            Please remember that in cura, the extrusion mode is set to absolute before the scripts are inserted even if relative extrusion mode is enabled in the cura settings. I know this is dumb but the cura devs insisted upon it.
            • darookee
              @Icthus:
              My printer is a HyperCube-y CoreXY using the extruder of the Wanhao i3 I ripped apart…
