    Generic voltage sensor
    229
    • drivetrainsystemsundefined
      drivetrainsystems
      I hope this isn't a question with an obvious answer, because I can't seem to find one.
      I have an optical sensor that varies it's output between 0-10 volts.
      What is the best way to configure a Mini5+ to read that sensor?
      What is the best way to then get that reading?
      @dc42 this sounds like something you may know off the top of your head 🙂
      drivetrainsystemsundefined 1 Reply Last reply Reply Quote 0
        drivetrainsystems @drivetrainsystems
        I have found
        M308 S0 P"io6in" Y"linear-analog" A"DNAreader" F0
        maybe effectively sets up the sensor, and
        M308 S0
        reads the sensors value.
        I'm wondering though, how can I configure the sensor to be sensitive to the voltage range of the optical reader: 0-10v?
        dc42undefined o_lampeundefined infiniteloopundefined drivetrainsystemsundefined 4 Replies Last reply Reply Quote 0
          dc42 administrators @drivetrainsystems
          @drivetrainsystems use a voltage divider (2 resistors) to reduce the voltage to the range 0 to 3.3V.
          • o_lampeundefined
            o_lampe @drivetrainsystems
            @drivetrainsystems
            Also use B and C values :
            Additional parameters for linear analog sensors
                Fn F0 = unfiltered (fast response), F1 = filtered (slower response, but noise reduced and ADC oversampling used to increase resolution). F1 is only available when using a port intended for thermistors, not when using a general input port.
                Bnnn The temperature or other value when the ADC output is zero
                Cnnn The temperature or other value when the ADC output is full scale
            • infiniteloopundefined
              infiniteloop @drivetrainsystems
              @drivetrainsystems See this thread - reading-sensor-pressure-from-analog-output for details. You can skip the posts involving the "Bi-directional Level Shifter" which returns a digital signal.
                @dc42 do understand correctly that the value reported by M308 S0 in my above example (applying your voltage divider) will be a reflection of the voltage detected between the outer pins of io6in?
                For instance, if I configure the reply value range for 0-100, and my sensor generates 5v (dropped to ~1.65v), will M308 S0 report a value of 50? (hope my details are sensible, I'm not quite yet grasping all the particulars of the process)
                dc42undefined drivetrainsystemsundefined 2 Replies Last reply Reply Quote 0
                  @drivetrainsystems that's correct, except that there is a 27Kohm pullup resistor to +3.3V on each IO_IN input which will affect the reading a little. It's not hard to calculate how much.
                    @dc42 unfortunately my electronics skills are limited. I can put the calc in front of my electronics guy, unless you know what to do off the top of your head? iIf so, I can put your formula into the software ASAP,
                      @drivetrainsystems I've put a spreadsheet that you can copy to calculate it at https://docs.google.com/spreadsheets/d/1RHeHdqUFcPJ-TeWF9t5B-z-C7YzHEIGwSDQcROe8kqE/edit?usp=sharing.
                        @dc42 thanks!
