Duet2 wifi: Motor Driver & Connector heating issue
I am using a Duet 2 WiFi with RRF 3.5.2rc1.
My setup includes three Z motors connected to the Z, E1, and E2 connectors, with the X and Y motors connected to their respective axes. The motor current is configured at 1600mA for all motors, while their rated capacity is 2500mA.
;M-curr M906 X1600 Y1600 Z1600 E800 I50 M84 S30
I have observed that when the axes are at their home positions, the motor connectors heat up significantly, which appears unusual. However, after homing, if I jog the axes, the connectors cool down to a normal temperature. Additionally, there is a fan installed that blows air directly onto the board.
What could be the cause of the connectors heating up?
Occasionally, the drivers also overheat. What might be causing this issue, and how can it be resolved? -
@R006 said in Duet2 wifi: Motor Driver & Connector heating issue:
RRF 3.5.2rc1.
Please update to 3.5.4 and see if the be behaviour continues.
Also please post your config.g and homing files. -
@Phaedrux
Homeall.gG91 G1 H2 Z2 F100 G1 H1 X-300 Y-300 F600 G1 H2 X5 Y5 F1000 G1 H1 X-300 Y-300 F200 G1 H2 Z-5 F100 G1 H1 Z304.1 F300 G1 H2 Z-2 F100 G1 H1 Z304.1 F100 G92 X0 Y0 G90 G92 Z304.1
homex.g
G91 G1 H2 Z2 F100 G1 H1 X-300 F600 G1 H2 X5 F600 G1 H1 X-300 F200 G1 H2 Z-2 F100 G92 X0 G90
homey.g
G91 G1 H2 Z2 F100 G1 H1 Y-300 F600 G1 H2 Y5 F600 G1 H1 Y-300 F200 G1 H2 Z-2 F100 G92 Y0 G90
homez.g
G91 G1 H2 Z2 F300 G1 H1 Z304.1 F360 G1 H2 Z-5 F240 G1 H1 Z304.1 F200 G90 G92 Z304.1
config.g
M552 S1 ;M552 S-1 M586 P0 S1 M586 P1 S0 M586 P2 S0 ; Drives M569 P0 S1 M569 P1 S1 M569 P2 S1 M569 P3 S1 M569 P4 S1 M569 P5 S1 M584 X0 Y1 Z2:3:4 E5 M350 X32 Y32 I0 M350 Z16 E16 I1 M92 X160.0 Y160.0 Z2133.33 E932.00 ;change as per machine M566 X720.00 Y720.00 Z300.00 E600.00 M203 X8400.00 Y8400.00 Z420.00 E8400.00 M201 X3000.00 Y3000.00 Z30.00 E250.00 ;M-curr M906 X1600 Y1600 Z1600 E800 I50 M84 S30 ; Axis Limits M208 X0 Y0 Z0 S1 M208 X300 Y300 Z304.1 S0 ; filament Sensor M591 D0 P7 C"exp.e3stop" R15:300 L7 E17 S1 ; Endstops M574 X1 S1 P"xstop" M574 Y1 S1 P"ystop" M574 Z1 S1 P"zstop+e0_stop+e1_stop" ; Z-Probe M950 S0 C"exp.heater3" M558 P9 C"^zprobe.in" H5 F120 T6000 G31 P500 X0 Y0 Z1.038 ; Auto level, coordinates as per motor order in M584 M671 X-17.66:297.34:140.00 Y-5.00:-5.00:327.61 S5.0 F1.2 ; define mesh grid M557 X30:300 Y30:300 S20 M376 H5 ; End Limits M950 J1 C"exp.e4stop" M581 P1 T2 R0 S1 M582 T2 M581 P-1 T2 M581 P1 T0 R0 S1 ;PA M572 D0 S0.045 ; Bed Heater M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 M950 H0 C"bedheat" T0 M307 H0 B0 S1.00 M140 H0 M143 H0 S105 ; Extuder Heater M308 S1 P"e0temp" Y"pt1000" M950 H1 C"e0heat" T1 M307 H1 B0 S1.00 M143 H1 S320 ; cooling Fans M950 F0 C"fan0" Q500 M106 P0 S0 H-1 M950 F1 C"fan1" Q500 M106 P1 S0 H-1 ; Tools M563 P0 D0 H1 F0 G10 P0 X0 Y0 Z0 G10 P0 R0 S0 M575 P1 S1 B57600 M501 M911 S21 R22.5 P"M913 X0 Y0 G91 M83 G1 Z5 E-5 F1000" M929 S3 P"/macros/SERVICE/log/STPL_DEBUG.txt"
