    Strange motor noise with 3.6.0-beta.2
    Beta Firmware
    327
    • balajiramaniundefined
      balajiramani
      I updated to 3.6.0-beta.2 and I noticed that there were some strange motor noise during printing. I also noticed that there were some layer shifts some times. I am attaching a video that shows the noise. I later lowered the acceleration for both X and Y from 4000 to 1000 and the noise went away. I went back to 3.6.0-beta.1 and noticed that there were no issues and the printer is able to handle the acceleration value of 4000.
      The printer I have is a delta (not sure if this is something specific to a delta).
      Here is the gcode that triggered the issue
      22-334StringStar2L2N4open_0.2mm_PLA_BigDelta_12m.gcode
      Here is the video that shows the motor noise - https://photos.app.goo.gl/dX5uqjCsf5SBth4Y9
        droftarts administrators @balajiramani
        @balajiramani It's difficult to know what noise is 'strange', or where it's coming from. Is it the 'hissing' noise? Is it coming from the delta tower motors, or the extruder? What Duet board are you using? Are you using input shaping? Please post your config.g and response to M122.
        oliofundefined balajiramaniundefined 2 Replies Last reply Reply Quote 0
        • oliofundefined
          oliof @droftarts
          Also, what release did you do the update from? There was a time when RRFdefaulted to stealth chop; spreadcycle is the new default
            droftarts administrators @oliof
            @oliof he did say it was between 3.6.0-beta1 and 3.6.0-beta2.
              balajiramani @droftarts
              @droftarts The hissing sound is from the fans. The noise that I am referring to can be heard at 7 and 19 seconds in the video. It is from the delta tower motors. I am using a Duet Wifi 2 board. Input shaping is turned on. Here is the config.g file. Here is the output of M122 when the issue arises:
              M122
              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.6.0-beta.2 (2024-11-12 08:12:30) running on Duet WiFi 1.0 or 1.01
              Board ID: 08DAM-999TL-MQ4SD-6JTDL-3SS6N-968BX
              Used output buffers: 3 of 26 (19 max)
              Static ram: 23536
              Dynamic ram: 67308 of which 12 recycled
              Never used RAM 9316, free system stack 122 words
              Tasks: NETWORK(1,ready,23.3%,195) HEAT(3,nWait 5,0.1%,328) Move(4,nWait 5,7.4%,264) MAIN(1,running,69.2%,742) IDLE(0,ready,0.0%,29), total 100.0%
              Owned mutexes:
              Last reset 00:08:48 ago, cause: software
              Last software reset at 2024-12-08 19:04, reason: User, Gcodes spinning, available RAM 12172, slot 2
              Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
              Error status: 0x00
              Aux0 errors 0,0,0
              MCU temperature: min 35.8, current 36.0, max 36.5
              Supply voltage: min 23.6, current 24.2, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
              Heap OK, handles allocated/used 99/2, heap memory allocated/used/recyclable 2048/1140/1072, gc cycles 1
              Events: 0 queued, 0 completed
              Date/time: 2024-12-11 20:25:22
              Slowest loop: 16.23ms; fastest: 0.14ms
              === Storage ===
              Free file entries: 8
              SD card longest read time 0.9ms, write time 0.0ms, max retries 0
              Segments created 746, maxWait 45ms, bed comp in use: none, height map offset 0.000, hiccups added 65/0 (0.00ms), max steps late 0, ebfmin 0.00, ebfmax 0.00
              Pos req/act/dcf: 67028.00/66704/0.74 63402.00/63796/-0.93 68665.00/68591/-0.77
              next step interrupt due in 68 ticks, disabled
              Driver 0: stalled, SG min 0
              Driver 1: ok, SG min 0
              Driver 2: ok, SG min 0
              Driver 3: ok, SG min 0
              Driver 4: standstill, SG min n/a
              Driver 5:
              Driver 6:
              Driver 7:
              Driver 8:
              Driver 9:
              Driver 10:
              Driver 11:
              === DDARing 0 ===
              Scheduled moves 3130, completed 3091, LaErrors 0, Underruns [0, 0, 0]
              Heater 0 is on, I-accum = 0.2
              Heater 1 is on, I-accum = 0.2
              Movement locks held by null
              HTTP is idle in state(s) 0
              Telnet is idle in state(s) 0
              File is idle in state(s) 3
              USB is idle in state(s) 0
              Aux is idle in state(s) 0
              Trigger is idle in state(s) 0
              Queue is idle in state(s) 0
              LCD is idle in state(s) 0
              Daemon is idle in state(s) 0
              Q0 segments left 0
              Code queue 0 is empty
              === Network ===
              Slowest loop: 22.00ms; fastest: 0.07ms
              Responder states: HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
              HTTP sessions: 1 of 8
              === WiFi ===
              Interface state: active
              Firmware version 2.2.0
              MAC address 5c:cf:7f:2c:25:00
              Module reset reason: Turned on by main processor, Vcc 3.40, flash size 4194304, free heap 40844
              WiFi IP address 192.168.1.61
              Signal strength -46dBm, channel 6, mode 802.11n, reconnections 0
              Clock register 00002002
              balajiramaniundefined 1 Reply Last reply Reply Quote 0
                balajiramani @balajiramani
                @dc42 were you able to take a look at this? I built the latest dev release and I still the same issue.
                  dc42 administrators @balajiramani
                  @balajiramani I am aware of issues with some move speeds not being correct in 3.6 beta releases, and this may explain the noises. Please try beta 3 when it is released. I may also make an unofficial build available before beta 3 for the community to try.
                    balajiramani @dc42
                    @dc42 Thank you for the update. I will wait for the next release.
