    Concept: full color 3d printing with no waste
    3D Printing General Chat
    • Pyperundefined
      Pyper
      Just a concept:
      with DaVinci providing filament made for inkjet printing ink, could you put a USB driven inkjet printhead behind/in front/beside(idex) the regular filament printhead and inkjet print color onto each layer..? kind of a poor mans polyjet. I saw the 'print full color using sharpie markers' but everyone says using the markers affects print layer adhesion. This way you would print a layer using filament, then print inkjet ink onto the outside layers, then move up for the next layer etc. Now waste, full color. Worth exploring?
      • oliofundefined
        oliof @Pyper
        @Pyper inkjet coloring has been done in the past and RRF did have some basic support to control inkjet heads in the past (I dont know if that is still in source). The drawbacks to this approach are that the colors are ususally limited to light and muted, i.e. it'll be hard to get vibrant blues or reds.
        Pyperundefined 1 Reply Last reply Reply Quote 0
        • Pyperundefined
          Pyper @oliof
          @oliof
          as if on cue!
          https://youtu.be/J1wz8S9rTI8?si=336JVNOTmP4rH9oB
          oliofundefined 1 Reply Last reply Reply Quote 1
          • oliofundefined
            oliof @Pyper
            @Pyper yeah and you can see a pretty neon-ish/pink leaning light/muted color palette on the print sample (-:
