Bed temperature sensor spiking when heating up
Hi Guys,
Been starting to convert an Ultimaker2 (2nd hand) machine to Duet with a Duet 3 Mainboard 6HC mainboard including the PT100 extention board for PT100 compatibility.Board: Duet 3 MB6HC (MB6HC)
Firmware: RepRapFirmware for Duet 3 MB6HC 3.4.5 (2022-11-30) - didnt bother to update yet.So far the wiring looks fine - basic functionality is given.
Unfortunately when heating up the printbed the values start going up as intened only in the beginning (from around 22- ~45 °C), then the reading starts spiking.
When restarting the machine/board the reading looks fine again.Any pointers what the procedure of debugging would be here?
; Heaters M308 S0 P"spi.cs0" Y"rtd-max31865" ; configure sensor 0 as PT100 on pin spi.cs0 M950 H0 C"out0" T0 ; create bed heater output on out0 and map it to sensor 0 M307 H0 R0.270 K0.221:0.000 D0.53 E1.35 S1.00 B0 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S130 ; set temperature limit for heater 0 to 130C M301 H0 P124.55 I23.46 D165.29 ; old PID-Values UM (M) M308 S1 P"spi.cs1" Y"rtd-max31865" ; configure sensor 1 as PT100 on pin spi.cs1 M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1 M307 H1 R2.103 K0.294:0.000 D8.88 E1.35 S1.00 B0 V24.0 ; disable bang-bang mode for heater and set PWM limit M143 H1 S350 ; set temperature limit for heater 1 to 280C
After restarting the board
@mmcc Generally, in order of most likely to least likely, spiky temperature readings are caused by:
- intermittent wiring - loose connections, poor crimping, frayed wires, dry solder joints. It may only happen when the wiring moves, or when temperature changes.
- failing temperature sensor - may only show when at temperature
- Electrical interference - usually from heater or motor wiring running very close to the temperature sensor wiring. Generally shows when machine is operating
- Power supply issues - faulty or failing power supply, external power spikes (eg large/noisy dc motor on the same electrical circuit starting/stopping)
- Hardware issues - faulty Duet board.
- Firmware bug - least likely because this is heavily tested, and would be reported by other users.
@mmcc as @droftarts said. For a PT100, if you see positive spikes then a bad connection between the daughter board and the sensor is most likely. If the wires are long or there are any connectors in the wiring then I strongly recommend using a 4-wire connection.
