    "M569: expected numeric operand" error.
    DSF Development
    377
    • LindsayCundefined
      LindsayC
      I'm trying to use the object model "move.axes[X].drivers[0]" can and driver address to use in M569.X commands to setup closed loop (1hcl) during a home without having to specifically put it in the can address into the home file. Essentially I search for the drive letter, and when I've found it I want to set a variable that has the address. Unfortunately there doesn't seem to be away to turn the string "51.0" in the object model into 51.0 (float?) in the m569.X commands. For instance.
      var address = 51.0
      M569.1 P{var.address} T2 C1000 S200 R150 I50 D0.1 V500 A1 E4.0:2.0 D1;
      Will work fine.
      But below code gives a "M569: expected numeric operand" error.
      var ind = 0
      var driverAddress = 0.0
      while exists (move.axes[{var.ind}].letter) ;go through all axis in order till I find the correct one.
      if move.axes[{var.ind}].letter == "'a"
      set var.driverAddress = move.axes[{var.ind}].drivers[0]
      set var.ind = var.ind +1;
      M569.1 P{var.driverAddress} T2 C1000 S200 R150 I50 D0.1 V500 A1 E4.0:2.0 D1;
        dc42 administrators @LindsayC
        @LindsayC which firmware version? SBC or standalone mode?
        • T3P3Tonyundefined
          T3P3Tony administrators @dc42
          @dc42 @LindsayC I have recreated this issue in SBC and stand alone mode (3.6beta3 test build).
          SBC mode:
          var addr = move.axes[0].drivers[0]
          then
          echo var.addr
          returns:
          {object}
          attempting to do anything numerical with that variable results in
          Error: expected numeric operands
          Stand alone:
          then
          echo var.addr
          returns:
          0.0
          www.duet3d.com
            dc42 administrators @T3P3Tony
            @T3P3Tony that's expected. A driver ID is not a number because it holds both the CAN address and the driver number at that address. However, it should be allowed as the P operand in a M569 command.
            T3P3Tonyundefined dc42undefined 2 Replies Last reply Reply Quote 0
            • T3P3Tonyundefined
              @dc42 Thanks I have tested that in Stand alone and SBC mode and confirm it works in standalone mode but not in SBC mode.
              Stand alone:
              M569 P{var.addr}
              Drive 0 runs forwards, active high enable, timing 4.0:4.0:1.3:1.3us, mode spreadCycle, ccr 0x08053, toff 3, tblank 1, thigh 200 (46.9 mm/sec), gs=32, iRun=0, iHold=0, current=25.391, hstart/hend/hdec 5/0/0, pos 8
              SBC:
              M569 P{var.addr}
              Error: M569: expected numeric operand
              www.duet3d.com
              • T3P3Tonyundefined T3P3Tony moved this topic from Gcode meta commands
                dc42 administrators @dc42
                The OP didn't respond to my request for the firmware version. A change was made to improve this area within the last few months, which is why I asked.
                LindsayCundefined 1 Reply Last reply Reply Quote 0
                • LindsayCundefined
                  LindsayC @dc42
                  Sorry, just got this.
                  It is on 3.5.3. In standalone mode.
                    @LindsayC thanks. Please upgrade to either 3.5.4 or 3.6.0-beta.4 and test again.
                    • LindsayCundefined
                      LindsayC @dc42
                      Upgraded to 3.6.0-rc.1.
                      And if I run this code:
                      var ind = 0
                      var driverAddress = 50.0
                      it fails with "Error: in file macro line 9 column 29: M569: expected numeric operand"
                      If I echo what the variable is. Ie this code:
                      var ind = 0
                      echo var.driverAddress
                      I get this from the console:
                      50.0
                      51.0
                      But if I run it with just a hard set driverAddress like below.
                      var ind = 0
                      var driverAddress = 51.0
                      It works fine with no error.
                      Output from console:
                      51.0
                      This is all on a duet3 in standalone mode.
                      • LindsayCundefined
                        LindsayC @LindsayC
                        @LindsayC
                        Did a bit more digging into what the type is. If you run this code:
                        var ind = 0
                        echo var.driverAddress;
                        echo var.driverAddress ^"1";
                        echo var.driverAddress * 2
                        echo var.driverAddress *2;
                        You get:
                        50.0
                        50.01
                        100.0
                        51.0
                        51.01
                        Error: in file macro line 14 column 26: meta command: expected numeric operands
                        So the variable returned from the object model for the driver can address can be treated as a string but not as a float. While the original set address that does work for the P parameter can be treated as both a float and a string.
                        • LindsayCundefined
                          LindsayC @LindsayC
                          @LindsayC
                          And finally if you run this code where you just pass a string to the P parameter.
                          var ind = 0
                          var driverAddress = "51.0"
                          You get this error message:
                          Error: in file macro line 3 column 27: M569: expected driver ID
                          Which is different to the error message you get if the variable is obtained from the object model.
                            @LindsayC the reason is that the P parameter of M569 expects a driver ID, which looks like a float but is different. To make it easier to generate the P parameter in a macro, in recent versions of RRF we allow a float with a fractional part that is very close to a multiple of 0.1 to be converted to a driver ID. We can't say that it has to be exactly a multiple of 0.1 because 0.1 cannot be represented exactly as a binary float.
                            Expressions of any type can be converted to string.
