CAN response timeout when mapping endstops
I've got a 6HC mainboard connected to EB3HC expansion board address 1.
The LEDs are blinking in sync. Both boards are at 3.4.6 firmware.
When I try to map the endstop on the expansion board, it does not seem to work and I get a CAN response timeout error.
Does anyone know what I'm doing wrong, or how to fix this? Thanks so much!
I cannot post my config.g because it complains I need a reputation 2 to post links even though it's just text.
@ChunkyPanda I've upvoted your posts, please post your config.g now, preferably as text in your reply not as a file. Also please post the response to M122, again as text. In code tags would be even better!
config.g
M575 P1 S1 B57600 ; enable support for PanelDue G90 M550 P"cp" M575 P1 S0 B57600 M552 S1 P0.0.0.0 M586 P0 S1 ; enable HTTP M586 P2 S1 ; enable Telnet G4 S2 ; wait for expansion boards to start M569 P0.1 S1 D2 ; driver 0.1 goes forwards (Y axis) M569 P0.2 S1 D2 ; driver 0.2 goes forwards (Z axis) M569 P1.0 S0 D2 ; drive M569 P1.1 S0 D2 M906 X400 A400 I30 ; motor currents and motor idle factor in per cent M84 S30 ; idle timeout M584 X1.0 Y0.1 Z0.2 A1.1 ; set axis mapping M350 X16 A16 I1 ; microstepping with interpolation M92 X{200*16} A{(66*200*16)/360} ; steps per unit M208 X0:50 A0:{100*360} ; axis limits M566 X900.00 A900.00 ; maximum instantaneous speed changes (u/min) M203 X{50*60} A{45*60} ; maximum speeds (u/min) M201 X50.00 A10.00 ; set accelerations (u/s^2) M669 K0 ; configure Cartesian kinematics M574 X1 P"1.io1.in" S1 ; configure X axis endstop M574 Y0 ; configure Y axis endstop M574 Z0 ; configure Z axis endstop M574 A1 P"1.io2.in" S1 ; configure A axis endstop M950 P0 C"out4" ; gas M950 P1 C"out5" ; laser shot M501 ; load saved parms from nv memory M453 -
m122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.4.6 (2023-07-21 14:11:38) running on Duet 3 MB6HC v1.02 or later (standalone mode) Board ID: 0JD2M-9P9DA-F0PS4-6JTDJ-3S46K-T6WM2 Used output buffers: 3 of 40 (20 max) === RTOS === Static ram: 153252 Dynamic ram: 96792 of which 0 recycled Never used RAM 100628, free system stack 190 words Tasks: NETWORK(ready,39.3%,169) ETHERNET(notifyWait,0.5%,108) HEAT(notifyWait,0.0%,373) Move(notifyWait,0.0%,344) CanReceiv(notifyWait,0.0%,798) CanSender(notifyWait,0.0%,335) CanClock(delaying,0.0%,349) TMC(notifyWait,7.7%,90) MAIN(running,52.3%,925) IDLE(ready,0.2%,30), total 100.0% Owned mutexes: === Platform === Last reset 00:30:06 ago, cause: software Last software reset at 2024-12-19 13:18, reason: User, GCodes spinning, available RAM 100628, slot 0 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00432000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 Step timer max interval 1409 MCU temperature: min 41.5, current 41.6, max 42.7 Supply voltage: min 24.2, current 24.3, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.1, current 12.2, max 12.3, under voltage events: 0 Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0 Events: 0 queued, 0 completed Driver 0: standstill, SG min 0, mspos 8, reads 49865, writes 13 timeouts 0 Driver 1: standstill, SG min 0, mspos 8, reads 49866, writes 12 timeouts 0 Driver 2: standstill, SG min 0, mspos 8, reads 49866, writes 12 timeouts 0 Driver 3: standstill, SG min 0, mspos 8, reads 49867, writes 11 timeouts 0 Driver 4: standstill, SG min 0, mspos 8, reads 49867, writes 11 timeouts 0 Driver 5: standstill, SG min 0, mspos 8, reads 49868, writes 11 timeouts 0 Date/time: 2024-12-19 13:48:39 Slowest loop: 999.97ms; fastest: 0.05ms === Storage === Free file entries: 10 SD card 0 detected, interface speed: 25.0MBytes/sec SD card longest read time 2.3ms, write time 0.0ms, max retries 0 === Move === DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty === CAN === Messages queued 9043, received 14459, lost 0, boc 0 Longest wait 1ms for reply type 6018, peak Tx sync delay 286, free buffers 50 (min 49), ts 9032/9031/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 899.24ms; fastest: 0.03ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0) HTTP sessions: 2 of 8 = Ethernet = State: active Error counts: 0 0 0 1 0 0 Socket states: 5 2 2 2 2 0 0 2 = WiFi = Interface state: disabled Module is disabled Failed messages: pending 0, notready 0, noresp 0 Socket states: 0 0 0 0 0 0 0 0 === Multicast handler === Responder is inactive, messages received 0, responses 0 -
@ChunkyPanda Can you send
M98 P"config.g"
and post the response?Ian
@ChunkyPanda I think it's because your 6HC is on a different firmware version compared to the 3HC, 3.4.6 vs 3.5.4. Update the 6HC to the same version.
The immediate response is
m98 P"config.g"
HTTP is enabled on port 80
TELNET is enabled on port 23But a few seconds later this is the response
Error: Response timeout: CAN addr 1, req type 6036, RID=18
Error: Response timeout: CAN addr 1, req type 6036, RID=19 -
My mistake... I'm sorry for mixing up the firmware numbers. I thought I had the latest firmware on both boards but I don't. I updated the firmware on the 6HC and it's now working.
Thanks so much for your help!
undefined dc42 marked this topic as a question 20 Dec 2024, 07:22
undefined dc42 has marked this topic as solved 20 Dec 2024, 07:23
