    Duet 2 Wifi Unstable/Slow Wifi Connection
    Duet Web Control
    343
    • h4ntyundefined
      h4nty
      From a few weeks ago I started to have connection issue on a duet 2 wifi. The machine I'm using is a custom-build tool-changer with duet 2 wifi motherboard. All prints appears to be very normal as long as they are uploaded.
      What I observed:
      1. The first time I noticed the issue is during one printing the web interface started to disconnect and reconnect every ~30 seconds. And shortly after, Orca slicer (which tends to refresh pretty frequently) device page started to show a blank white page.
      2. From that point, I'm experiencing unstable and slow connection to the web interface. Usually I need to reset the board every time I lost connection to the web interface and will be able to reconnect after the reset for once or twice. But the connection (time for the web interface to show up) and file upload speed are slow. Usually it takes about 20-30 seconds to load the DWC and file uploads is around 10-100 kb/s.
      What I've tried but didn't work:
      1. Updated firmware for duet 2 wifi, duet wifi server and duet web control. Currently it's at 3.5.3-rc.1, 2.1.0, 3.5.3-rc.1 respectively.
      2. Tried connecting from different browser. Orca slicer's build in browser is the worst as it will refresh the page every time I switch to "prepare" and "preview" tabs. Also tried Chrome and Firefox on windows, Safari on Mac and iPad. All have similar results.
      3. Tried a different router and reset the current router. I'm using a TP-link AC1750 router and tried both original firmware and Openwrt. Also tried using an Asus router or switching channels (currently at channel 11). All have similar results.
      4. Tried the suggestion "manually replace the /www folder with the contents of the DWC 2.0.7 zip file" from https://forum.duet3d.com/topic/14784/blank-page-after-update-of-duet-web-control.
      5. I'm using an always on 5V power supply and the ATX-power switch to control a 24V power supply. 5V only and 5V+24V shows similar results.
      Here's M112 return:
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.5.3-rc.1 (2024-08-27 16:09:54) running on Duet WiFi 1.02 or later
      Board ID: 0JD0M-9K662-MG5T4-6JTDG-3S06P-1BNGY
      Used output buffers: 2 of 26 (16 max)
      Static ram: 23384
      Dynamic ram: 75396 of which 0 recycled
      Never used RAM 10524, free system stack 106 words
      Tasks: NETWORK(1,ready,17.3%,181) ACCEL(6,nWait 5,0.0%,345) HEAT(3,nWait 5,0.1%,307) Move(4,nWait 5,2.4%,258) MAIN(1,running,80.2%,699) IDLE(0,ready,0.0%,29), total 100.0%
      Owned mutexes:
      Last reset 02:57:50 ago, cause: reset button or watchdog
      Last software reset at 2024-11-22 17:56, reason: User, Gcodes spinning, available RAM 14240, slot 2
      Error status: 0x00
      MCU temperature: min 27.8, current 36.3, max 38.5
      Supply voltage: min 0.5, current 24.3, max 25.0, under voltage events: 0, over voltage events: 0, power good: yes
      Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/96/96, gc cycles 0
      Events: 0 queued, 0 completed
      Driver 0: standstill, SG min 0
      Driver 1: standstill, SG min 0
      Driver 2: standstill, SG min n/a
      Driver 3: standstill, SG min 0
      Driver 4: standstill, SG min 0
      Driver 5:
      Driver 6:
      Driver 7:
      Driver 8:
      Driver 9:
      Driver 10:
      Driver 11:
      Date/time: 2024-12-21 20:14:23
      Slowest loop: 238.25ms; fastest: 0.12ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 10.0ms, write time 50.3ms, max retries 0
      DMs created 83, segments created 55, maxWait 556897ms, bed compensation in use: mesh, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 1.00
      no step interrupt scheduled
      Moves shaped first try 13755, on retry 573, too short 6531, wrong shape 47412, maybepossible 1873
      === DDARing 0 ===
      Scheduled moves 3088, completed 3088, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 17], CDDA state -1
      Heater 0 is on, I-accum = 0.0
      Movement locks held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Q0 segments left 0
      Code queue 0 is empty
      === Network ===
      Slowest loop: 183.53ms; fastest: 0.00ms
      Responder states: HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
      HTTP sessions: 1 of 8
      === WiFi ===
      Interface state: active
      Firmware version 2.1.0
      MAC address 48:3f:da:4f:6a:e9
      Module reset reason: Power up, Vcc 3.42, flash size 4194304, free heap 34644
      WiFi IP address 192.168.3.18
      Signal strength -41dBm, channel 11, mode 802.11n, reconnections 0
      Clock register 00002002
      Here's M122 P104 return:
      M122 P104
      Testing SD card write speed...
      SD write speed for 10.0MByte file was 3.35MBytes/sec
      Testing SD card read speed...
      SD read speed for 10.0MByte file was 1.41MBytes/sec
      Any feedback is welcomed, thanks!
        jay_s_uk @h4nty
        @h4nty update to 3.5.4. There's a new WiFi firmware which should fix what you're seeing
        h4ntyundefined 1 Reply Last reply Reply Quote 0
        • h4ntyundefined
          h4nty @jay_s_uk
          @jay_s_uk Thanks! I’ll try that as soon as I get back to my printer. May I ask if there’s a release note for this issue? I’ve checked the recent notes but failed to find any.
          jay_s_ukundefined dc42undefined 2 Replies Last reply Reply Quote 0
            jay_s_uk @h4nty
            @h4nty there's not a change log for the WiFi firmware as far as I know but it was this commit https://github.com/Duet3D/WiFiSocketServerRTOS/commit/00e9246350fdc9919afc4a69fbbacefbcf0f2ecd
            0 rechrtb committed to Duet3D/WiFiSocketServerRTOS
            Merge pull request #48 from Duet3D/2.2.0-dev
            2.2.0 Update
              dc42 administrators @h4nty
              @h4nty do you have a PanelDue on your machine? If so, is the WiFi connection more stable when you leave the PanelDue on its Setup page?
              • h4ntyundefined
                h4nty @jay_s_uk
                @jay_s_uk Thanks! I think the issue might start to occur shortly after I upgrade the firmware. I'm traveling and will update on this around Jan. 10. 😀
                • h4ntyundefined
                  h4nty @dc42
                  @dc42 Hi! No, I don't have a PanelDue. But I do have 2 external TMC 5160 wiring from the expansion ports and another GPIO port connecting to an Arduino to control the tool head servo.
                  • h4ntyundefined
                    h4nty
                    Hello! Just got back from traveling. (Sorry got delayed for a few days.) I tried updating to 3.5.4 which seems to fix the issue. I'll keep doing some test. Thanks a lot for the help.
