    Blank Page after update of Duet Web Control
    Duet Web Control
    792
    • A Former User?
      A Former User
      I just updated my duet web control and now all I see is a blank page. The tab at the top says Duet Web Control 2. Suggestions???
        It sounds like maybe the update didn't proceed properly.
        First check with a different browser to see if it's just a browser issue. If it still doesn't work, I would pop the SD card into a PC, and manually replace the /www folder with the contents of the DWC 2.0.7 zip file.
        • A Former User?
          A Former User @Phaedrux
          @Phaedrux I did try the different browser still same issue. Pulled SD card and loaded a fresh download of the DWC 2.0.7 to the card into the /www folder and still same issue. Blank screen
            What board and firmware version?
            Can you connect via USB and verify that it's actually loaded up?
            M115 will give the firmware version.
            M503 will try to read the contents of config.g to verify that the SD card has loaded config.g properly at startup.
            M112 will give a diagnostic report.
            A Former User? 4 Replies Last reply Reply Quote 0
            • A Former User?
              A Former User
              Maybe add M20 S2 P"/www" to the list?
              And if everything looks good, the developer console in f.ex. chrome has a network tab to help identify issues as well.
              (in chrome hit F12 key to bring up the developer console in a new tab then type in the url for the duet)
              A Former User? 2 Replies Last reply Reply Quote 0
              • A Former User?
                @Phaedrux So it will eventually load after about 15min and everything seems to be ok. Then I wanted to see if it was fixed so reloaded the page and we are back at the blank page
                • A Former User?
                  @Phaedrux
                  m115
                  FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 FIRMWARE_VERSION: 3.0 ELECTRONICS: Duet 3 MB6HC FIRMWARE_DATE: 2020-01-03b3
                  m503
                  ; generated by RepRapFirmware Configuration Tool v2.1.8 on Fri Mar 06 2020 14:56:26 GMT-0700 (Mountain Standard Time)
                  M550 P"Duet3 CNC" ; set printer name
                  M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP
                  M586 P0 S1 ; enable HTTP
                  M586 P1 S0 ; disable FTP
                  M586 P2 S0 ; disable Telnet
                  M569 P0.1 S0 ; physical drive 0.1 goes backwards
                  M569 P0.2 S0 ; physical drive 0.2 goes backwards
                  M569 P0.3 S0 ; physical drive 0.3 goes backwards
                  M584 X0.0:0.3 Y0.1 Z0.2 ; set drive mapping
                  M92 X80.00 Y80.00 Z400.00 E80.00 ; set steps per mm
                  M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
                  M203 X14000.00 Y14000.00 Z1800.00 E14000.00 ; set maximum speeds (mm/min)
                  M201 X500.00 Y500.00 Z20.00 E500.00 ; set accelerations (mm/s^2)
                  M906 X2800 Y2800 Z4200 E2800 I30 ; set motor currents (mA) and motor idle factor in per cent
                  M84 S30 ; Set idle timeout
                  M208 X2498 Y1245 Z130 S0 ; set axis maxima
                  M574 X1 S1 P"io0.in" ; configure active-high endstop for low end on X via pin io0.in
                  M574 Y1 S1 P"io1.in" ; configure active-high endstop for low end on Y via pin io1.in
                  M574 Z2 S1 P"io2.in" ; configure active-high endstop for high end on Z via pin io2.in
                  M558 P0 H5 F120 T12000 ; disable Z probe but set dive height, probe speed and travel speed
                  M557 X15:215 Y15:195 S20 ; define mesh grid
                  M308 S0 P"temp0" Y"thermistor" T1 B4138 ; configure sensor 0 as thermistor on pin temp0
                  M143 H0 S0 ; set temperature limit for heater 0 to 0C
                  M307 H0 B0 S0.00 ; disable bang-bang mode for the bed heater and set PWM limit
                  ; Custom settings
                  M307 H1 A-1 C-1 D-1 ; Disable Heater 1 so we can use it for a tool
                  M453 P0 R24000 F400 ; Set to CNC mode, using Tool 0, 24000 Max RPM, PWM Frequency 400hz
                  • A Former User?
                    A Former User @A Former User
                    @bearer said in Blank Page after update of Duet Web Control:
                    M20 S2 P"/www"
                    M20 S2 P"/www"
                    {"dir":"/www","first":0,"files":["html404.htm","language.xml.gz","reprap.htm.gz","*css","*fonts","*js","favicon.ico","*img","dwc.json","index.html","index.html.gz","favicon.ico.gz"],"next":0,"err":0}
                    • A Former User?
                      @bearer what am I looking for in the developer console? I have it open.
                      • A Former User?
                        This post is deleted!
                        • A Former User?
                          @Phaedrux I also seem to have just a ton of files in my system folder now. I have never seen this many before:
                            Looks like you might have accidentally placed the contents of the dwc zip file in the /sys folder instead of the /www folder.
                            • A Former User?
                              @Phaedrux Wow super rookie mistake.
                                no big deal. You have a backup of your SD card from before you started updating right?
                                • A Former User?
                                  @Phaedrux right...... No but I guess I need the practice and the lesson.
                                  • A Former User?
                                    @Phaedrux fixed and fixed, comes up no problem now. Thank you
                                    • h4ntyundefined h4nty referenced this topic
