Im new to these 3D printers but can someone help me please?
I purchased a ultibots d300vs+ with no knowledge about this printer. I been trying to figure it out but cant get anything going. the wifi isn't connected and anything I read and try isn't working. where am i doing this wrong?
I know the board its using is a Duet 2 WiFi and the SD card has files on it but not sure they are extras on it that i know of. I have an apple mac book pro that im using and am connected to the printer by USB and have loaded Serial Tools and still not sure what im doing. I was unaware this was like this and I guess in my understanding from the guy I got it from was it only needed the wifi setup.
@SelfHatenMarine the guy you bought it from is almost right, you only need to setup the wifi and then you can use the duet web control.
On a Mac, I would use the Terminal.app and the built-in
screen
command for the serial connection.I would suggest some quality time with the extensive documentation at https://docs.duet3d.com, especially the Getting Started page.
Also, make a backup of the SD card before changing anything.
