    hc6 with rasberry pi 4 fan control
    • scottcowenundefined
      scottcowen
      basically i want a temp controlled fan for the pi using the temp from the pi but with the ribbon cable attached how do i go about finding and using the pid from the pi and controlling a fan out put for it on the 6hc?
      • T3P3Tonyundefined
        T3P3Tony administrators @scottcowen
        @scottcowen one for @chrishamm to see if it would be possible to add a sensor that was reported from the Pi to allow the 6HC fan to be set to work thermostatically from it.
        In the meantime you can have it always running, the fan on my pi 5 is always running and it's not that loud
        www.duet3d.com
        scottcowenundefined 2 Replies Last reply Reply Quote 0
          scottcowen @T3P3Tony
          @T3P3Tony i can definitely do it that way and it not so much the noise its more the ability to know its warm, secondarily is there a way to display pi temp on dwc?
            @T3P3Tony i appreciate the help first time running this configuration
            • chrishammundefined
              chrishamm administrators @scottcowen
              @scottcowen You can query the object model value sbc.cpu.temperature to get the Pi's CPU temperature. It isn't directly possible to assign a thermostatic fan to that sensor reading, but you could create a daemon.g file and check it every few seconds. For example:
              if sbc.cpu.temperature > 50
                M106 P3 S1
              else
                M106 P3 S0
              Duet software engineer
              scottcowenundefined 1 Reply Last reply Reply Quote 1
                scottcowen @chrishamm
                @chrishamm nice i will give that a shot thank you
