    Toolboard1LC v Roto Toolboard
    • ortondaleundefined
      ortondale
      I have a standard V6 hot end running on a 1LC toolboard. I would like to switch to a V6 Revo Six hot end. Can I still use this toolboard or do I have to change to the roto toolboard.
      jay_s_ukundefined dc42undefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @ortondale
        @ortondale you can use the same toolboard
          dc42 administrators @ortondale
          @ortondale you can use your existing tool board. You will need to use the voltage converter supplied with the Revo to supply the 5V hot end fan; whereas the Roto Tool board has a 5V fan output so the converter is not needed.
