    Bent warped bed under the glass
    • magnets99undefined
      magnets99
      Hi All, I need to replace my PEI sheet which sits on glass which sits on a heated bed.
      it has annoying metal tabs which either hold the plate firm or lets the sheet sit flat (not both!)
      So i've bought a kit with a magnetic sticky sheet and some pei sheets sandwiched between sprung steel
      (this link, i chose the second one, with base)
      Problem is, the heated metal bed under the base is visibly warped
      Here is the map
      Screenshot taken after removing the glass then doing a bed level compensation.
      And you can see in the picture it bows in the middle under the straight edge
      my thoughts are:
      1. take the bed off and try and bend it flat, i'm not sure if i'm skilled enough or if i need special equipment.
      2. stick the magnetic sheet to the glass, this has the disadvantage of keeping the metal tabs, longer bed heat times and there is still a gap under the glass meaning uneven heating.
      I have tried:
      heating the bed up in case it was just contraction causing it to bow.
      Any advice on what i should do here?
      Newbie, but tries hard. Has a duet 2 Wifi with a Zesty nimble extruder driver on a watercooled block built into some sort ultimaker 3 chassis.
      martinvundefined 1 Reply Last reply Reply Quote 0
      • martinvundefined
        martinv @magnets99
        @magnets99 In my experience, trying to correct for errors in "the foundation" by fiddling with the layers on top never really results in a great outcome. It may be ... passable, but I suppose it depends what you're aiming for in terms of result. I have had better success in accepting that, in this case, the heating bed is warped, and source/build a new one. That bed looks kind of thin anyway? Depending on where you are, you might be able to get a replacement for not too much. I was looking at the RatRig website a while back and their beds aren't so expensive, though you will need to buy a new heating pad too, alas.
        I have those Energetic PEI print sheets on a number of printers and am very happy with them BTW. Also, I was not at all looking forward to the very much one time only job of sticking the magnetic sheet to a print bed, but it actually wasn't as difficult as I thought it would be.
          magnets99
          thanks, i can't seem to find my plate for replacement.
          I can find lots of the heating PCB but not the actual metal plate.
          I've tried
          bed plate
          plate
          heated plate
          ultimaker 2
          and HB13 which is silk-screened on the pcb heater underneath the plate
          any ideas?
          i'm in australia
