USB Host & Jumpers
DuetWifi
Ability to load gcode via USB THumb Drive/StickPT100 Daugher Board
2 Pin Jumpers instead of solder points. when using 2 wire PT100
Hi Adam
I will look at the PT100 board design again when we run another batch.
The processor we currently use for the Duetwifi does not have the capability to be a USB host to thats not possible without changing the MCU. on the other hand you can use a USB-SD card reader so its only a slightly more onerous step to pop the sd card out and into the Duet.
