    Folgertech FT5 Duet Upgrade
    My Duet controlled machine
    • bug2k22undefined
      bug2k22
      Picked up an old Folgertech FT5 a while ago. Finally got round to finishing the upgrade. Has many of the 713maker cnc upgraded mounts and brackets. Swapped out the old controller which was running Marlin with a Duet 6HC, Roto Toolboard, Microswiss NG extruder with a revo nozzle and a Dyze Design Horizon Z probe.
      It's not a fast printer but print quality seems good, probably needs a little tuning to get the best out of it.
      droftartsundefined 1 Reply Last reply Reply Quote 2
        droftarts administrators @bug2k22
        @bug2k22 That looks like it's begging for a bit of mass reduction on the X axis and X carriage, perhaps a swap to CoreXY, which would make it faster! Very tidy wiring, nice work.
        bug2k22undefined 1 Reply Last reply Reply Quote 0
        • bug2k22undefined
          bug2k22 @droftarts
          Yes, it's not the lightest, I did need to make up an extra adapter bracket to use the horizon strain gause z probe which added a little weight to the print head assembly. I see there are a few that have done corexy conversions on these printers. Besides slightly faster print speeds are there any other advantages to running corexy?
          I did use one of the high flow 0.4 revo nozzles which seems to easily manage 20mm3/s+ with pla, extrusion speed isn't going to be the limiting factor on this.
          • oliofundefined
            oliof
            one of the advantages of CoreXY is that the motors are static for both axes so you get right of the flying X motor. You pay for that with longer belt runs and a bit more challenging belt tension tuning.
            • Mr.Crispinundefined
              Mr.Crispin
              its just begging to be modded to be a corexy
