    Network Security - Which ports do Duets use?
    • DocTruckerundefined
      DocTrucker
      Hello!
      I am looking to revisit my office/workshop network. I have a subnet which I have allocated for devices like 2D printers and my Duet based machines. What IP ports will I need to allow from my computer subnet to this one? Most of my machines are Duet2 boards, with one Duet 3 running through a Raspberry Pi. I appreciate that I would need to give the Raspberry Pi system additional privileges (perhaps temporary) to access the internet for updates. Are file uploads through the webpages all handled through port 80?
      Thanks!
      droftartsundefined chrishammundefined 2 Replies Last reply Reply Quote 0
        droftarts administrators @DocTrucker
        @DocTrucker What ports are open depends on what you have enabled in config.g with M586. The services use the default port for that service, though you can set your own port using M586 R parameter. Sending M586 on it's own should show what ports are enabled on your Duet. I get (Duet 3 Mini 5+ WiFi on RRF 3.6.0-beta.3, http and ftp enabled in config.g):
        M586
        CORS disabled
        HTTP is enabled on port 80
        FTP is enabled on port 21
        TELNET is disabled
        MQTT is disabled
        To confirm, I did a port scan from Terminal in MacOS:
        Ian@Ians-MacBook ~ % nc -z 192.168.1.182 1-65535
        Connection to 192.168.1.182 port 21 [tcp/ftp] succeeded!
        Connection to 192.168.1.182 port 80 [tcp/http] succeeded!
        Not sure about what ports the Raspberry Pi has open. One for @chrishamm !
        DocTruckerundefined 1 Reply Last reply Reply Quote 1
          DocTrucker @droftarts
          @droftarts Thanks Ian. MQTT is interesting, learnt something by mistake there!
          As far as I understand it the Duet never attempts to contact the outside world, other than with clients that have established connection to the HTTP port, or perhaps the MQTT server/client, but I'll read up on that another time.
          Knowing what the raspberry pi can be cut back to is a little more tricky as it will have to allow for "apt-get [update/upgrade]" and whatever other applications have been loaded on. I'm thinking about a script that will allow temporary external access for updates.
          Just to clarify, I'm not worried about what the duets are up to, but I would like to limit general access to the outside WAN so the paper printer isn't trying to phone home, or more concerning any cheap web cams!
          droftartsundefined 1 Reply Last reply Reply Quote 1
            @DocTrucker said in Network Security - Which ports do Duets use?:
            It was added with 3.5, but not something I've set up. See https://docs.duet3d.com/User_manual/Reference/Gcodes#m5864-configure-mqtt-client and https://github.com/Duet3D/MQTT-WPA2-Enterprise-Demo.
            • chrishammundefined
              chrishamm administrators @DocTrucker
              @DocTrucker Yes, port 80 should suffice. If you want to enable more services like SSH you will need to open those ports as well. For updates from the SBC you should permit outgoing HTTPS connections.
              Duet software engineer
                DocTrucker @chrishamm
                @chrishamm Thanks. Regards ssh, I assume that's only on the duets with a RPi or similar. Normal duet controller boatds don't do ssh do they?
                  @DocTrucker That's right, but you could enable the Telnet port if you wanted to.
