    duetBackup Error listing files!!
    Third-party software
    470
    • tfranssenundefined
      tfranssen
      Hi
      @stuartofmt Picking up here from the GH issue.
      I have an issue while installing the plugin i get the error. Failed to install package PyGithub==2.1.1
      I just solved this by installing it manually using SSH.
      pip3 install PyGithub
      I now have a new issue stating Error listing files!!
      I have searched in several places but I cannot find the logging for this service.
      stuartofmtundefined 2 Replies Last reply Reply Quote 0
      • stuartofmtundefined
        stuartofmt @tfranssen
        This post is deleted!
          @tfranssen
          Hi and thanks for posting in the forum.
          First up - the installation of the python dependencies is a function of the Duet Plugin Service. So the fact that it objected suggests there is some form of error and that could be related to permissions which in turn could account for the inability to resolve a file list (in general, often permission related).
          Please include a logfile (DuetBackup) with -verbose set and, as well your overall environment (SBC OS and version, Duet versions etc).
          If you stop the plugin, run this command in an OS console then attempt to restart the plugin, you will see progress / errors:
          env SYSTEMD_LESS=RXMK /usr/bin/journalctl -f
          stuartofmtundefined 1 Reply Last reply Reply Quote 0
            stuartofmt @stuartofmt
            @tfranssen
            Have you solved the issue (if so how) or is this still a problem?
            guywinslowundefined 1 Reply Last reply Reply Quote 0
            • guywinslowundefined
              guywinslow @stuartofmt
              @stuartofmt Sorry it took me so long to replay, Hear is the log file:log.txt
                guywinslow @guywinslow
                @guywinslow Sorry, thought this was the post i did on same problem
                  stuartofmt @guywinslow
                  @guywinslow
                  I've been meaning to add a log file to this plugin for some time.
                  The logfile is sys/duetBackup/duetBackup.log (i.e. same dir as the config file).
                  Other than the log file - I put in some code to report permissions. Can you please run this version (remove the .txt extension) of the plugin and use a config file like below (and then post duetBackup.log
                  -userName <your info>
                  -userToken <your info>
                  -rep <your info>
                  -dir sd/sys
                  -dir sd/macros
                  -days 0
                  -hours 0
                  -ignore *.log
                  -verbose
                  [plugin.zip]
                    @stuartofmt said in duetBackup Error listing files!!:
                    duetBackup.log
                    no log file created
                    Error Message Box:
                    Failed to start plugin
                    An error occurred trying to start process '/opt/dsf/plugins/duetBackup/dsf/duetBackup.py' with working directory '/opt/dsf/plugins/duetBackup/dsf'. Exec format error
                      @guywinslow
                      Very strange indeed ...
                      What version of Duet Software version are you using ? If it's 3.5.x try this. The plugin manager invokes plugins slightly differently than 3.6. The previous version was ambiguous ..
                      3.5 plugin.zip.txt
                      What SBC hardware ?
                      What OS version ?
                      At a console - what is the result of this command?
                      ls -l /opt/dsf/plugins
                      Can you try uninstall and then reinstall but before you reinstall run the following (just tails the plugin service logs) from the console to get any installation errors.
                      env SYSTEMD_LESS=RXMK /usr/bin/journalctl -u duetpluginservice -f
                        What SBC hardware: Raspberry PI 4
                        What OS version:
                        pi@railcore:~ $ cat /etc/os-release
                        PRETTY_NAME="Raspbian GNU/Linux 12 (bookworm)"
                        NAME="Raspbian GNU/Linux"
                        VERSION_ID="12"
                        VERSION="12 (bookworm)"
                        VERSION_CODENAME=bookworm
                        ID=raspbian
                        ID_LIKE=debian
                        Duet Version: 3 6HC board
                        Duet Firmware: 3.5.4
                          @guywinslow pi@railcore:~ $ ls -l /opt/dsf/plugins
                          total 40
                          drwxrwxr-x 3 dsf dsf 4096 Mar 2 10:49 CANManager
                          -rw-rw-r-- 1 dsf dsf 707 Mar 2 10:49 CANManager.json
                          drwxrwxr-x 3 dsf dsf 4096 Mar 4 08:42 duetBackup
                          -rw-rw-r-- 1 dsf dsf 843 Mar 4 08:42 duetBackup.json
                          drwxr-xr-x 3 dsf dsf 4096 Dec 4 01:07 DuetPiManagementPlugin
                          -r--r----- 1 dsf dsf 8737 Nov 25 09:29 DuetPiManagementPlugin.json
                          drwxrwxr-x 3 dsf dsf 4096 Oct 7 22:43 SpyglassWebcamServer
                          -rw-rw-r-- 1 dsf dsf 1307 Oct 7 22:43 SpyglassWebcamServer.json
                            @guywinslow Ok Interesting. I uninstalled the plug in you had me try and installed the duetBackup-3.5.x.zip file i got from your git hub sight and it appears to be working now. At lest according to the log i ran with this command 'env SYSTEMD_LESS=RXMK /usr/bin/journalctl -u duetpluginservice -f'
                              @guywinslow Secound run Log.txt
                                @guywinslow
                                Ok - that's good news but a mystery as to why it did not work the first time, as I assume you, effectively, just reinstalled from github.
                                If you had used the version I posted yesterday - there would have been a duetBackup ONLY log created (along with additional debug information) that you could access directly using the DWC UI.
                                The version that I sent to you yesterday will be the version posted in github soon. I do not use github for "in progress" builds - just for version bumps, once they are tested.
                                While I have tested on my 3.6 beta build - It would be very helpful if you could validate it against your 3.5 build.
                                Can you do that for me? I.e. Try the version I posted yesterday.
                                P.S. The permissions dsf:dsf from the ls -l look correct - so there may have been some other issue.
