    M291: cancel vs timeout
    • Leonard03undefined
      Leonard03
      Is there any way to tell if a dialog box with a cancel button has been cancelled or it has timed out?
      • T3P3Tonyundefined
        T3P3Tony administrators @Leonard03
        @Leonard03 from the documentation:
        Jn (RRF 3.5 and later only, optional) If message box mode >= 4: 0 = no Cancel button (default), 1 = display a Cancel button (job/macro is cancelled immediately when pressed or when it times out); 2 (RRF 3.6.0-beta.3 and later) = dispay a Cancel button (result variable is set to -1 when pressed or when timeout is reached).
        So not from the result.
        You could check the time before and after and see if the timeout length was reached but that's not necessarily foolproof.
        Why do you need to distinguish between those options?
        www.duet3d.com
        Leonard03undefined 1 Reply Last reply Reply Quote 0
          Leonard03 @T3P3Tony
          @T3P3Tony Thank you for your replay
          Regarding checking the time, I already tried this using daemon, but if a blocking dialog is already active, the response from daemon is somehow in background, so I need to do something with the active one and after that daemon can show its dialog.
          In short: I would like to do a "heater timeout" to cool the nozzle if I'm not around the printer if an event has occurred.
          The long version:
          If manual cancel and the timeout can be distinct, it would be possible to distinguish between an "automatic" action or an user input.
          Lets take the case of a filament runout:
          Just lift the nozzle a bit and wait there, at temperature, but Without pausing.
          if I am around the printer when the runout has occurred I can tell the printer to reload a new spool and continue, without pausing the job (parking the nozzle).
          Else if, I am around the printer but I don't have a new spool prepared at hand.
          in this case, park the nozzle but keep the heater on.
          Else, if I'm not around pause the print AND turn off the hotend heater, eg. overnight
          My particular case is this:
          while true
          	M98 P"0:/sys/MMU Control/moveIdler.g" S5
          	M291 P"FINDA didn't switch off while unloading filament. Try unloading manually. Ensure filament can move and FINDA works." R"FINDA FILAM. STUCK" S4 J0 K{"Retry","PAUSE",} F0
          	if input = 0
          		M98 P"0:/sys/MMU Control/moveIdler.g" S0
          		M98 P"0:/sys/MMU Control/unloadToPTFE.g"
          		if global.errQueue[#global.errQueue-1] != "FINDA_FILAMENT_STUCK"
          			break
          		else
          			continue
          	else
          		set global.tcBlock = true
          		if state.status = "processing"
          			set global.pause = true
          				M226
          			break
          If lets say the cancel button can set the result = -1 and the timeout can set the result = -2 the above can be changed to this
          while true
          	M291 P"FINDA didn't switch off while unloading filament. Try unloading manually. Ensure filament can move and FINDA works." R"FINDA FILAM. STUCK" S4 J2 K{"Retry",} F0 T600
          	if input = 0	; retry button
          			break
          		else
          			continue
          	elif result = -1	; cancel button, pause the print
          			M226
          			break
          	elif result = -2	; timeout after 10 minutes, pause the print
          			M568 P0 A0	;turn off heater 0
          			M226
          			break
          • T3P3Tonyundefined
            @Leonard03 thanks for the example. I can see how it could be useful. Once concern with making (for example) user action rather than timeout -2 would be a breaking change where peoples existing scripts would not work if they explicitly checked for -1.
            Lets see what @dc42 thinks - there may be another way to achieve what you need.
            www.duet3d.com
              Leonard03 @T3P3Tony
              @T3P3Tony That's fantastic, thank you!
              @T3P3Tony said in M291: cancel vs timeout:
              I thought about that and there might be some ideas for this.
              First, don't include an timeout in the M291 line, so the result can never be -2 for example.
              Second, in existing macros that works, the only modification that might need is instead of an result = -1 to result <= -1 so the behavior might remain unchanged (right?)
              Those are only my ideas. Any feedback is welcomed 😊
