DuetWifi stopped working unexpectedly
Earlier today printer stopped mid print and since, I have been unable to connect to the board using bossa. Red diagnostic LED lit at all times. Board not recognized once plugged in via usb under device manager. Tried MacOS as well with same result. Is the board dead? What could have happened?
@biomed27 try unplugging everything from the board other than the USB and seeing if it connects then.
@T3P3Tony I've tried that. Board not recognized and red diag led solid. Thank you for suggestion
Work your way through this guide and see if you can get the board to show up in bossa by clearing the firmware with the erase jumper/button.
https://docs.duet3d.com/en/User_manual/Troubleshooting/Duet_wont_respond
