    [3.6.0-beta3] Macro race condition?
    Beta Firmware
    341
    • stuartofmtundefined
      stuartofmt
      I encountered an issue with M291 where the K array seem to sometimes carry over to a subsequent call.
      I'm using 3.6.0-beta.3 on Rpi Bookworm with a Mini5+
      I do not recall seeing this issue on previous versions.
      Below is a skeletal macro that exhibits the problem.
      To reproduce:
      Run the macro and when the first popup appears QUICKLY (I'm not sure how important that is) - select one of the options.
      Sometimes (may take 3 or 5 attempts) the next popup appears as below:
      Placing a delay G4 P250 (line 25) between the M291 calls seems to resolve the issue.
      Test Macro
      var P_X_points = 0
      var P_Y_points = 0
      var set_temp = false
      M291 R"How Many Probe points" P"Select a number" K{"9","16","64","100","Cancel"} S4
      if input == 0
          set var.P_X_points = 3
          set var.P_Y_points = 3
      elif input == 1
          set var.P_X_points = 4
          set var.P_Y_points = 4
      elif input == 2
          set var.P_X_points = 8
          set var.P_Y_points = 8
      elif input == 3
          set var.P_X_points = 10
          set var.P_Y_points = 10
      else
          abort "Selection cancelled"
      ;  Delay to stop issue - comment out to reproduce
      ;G4 P250
      M291 R"Hot or Cold Calibration" P"Turn on Heaters" K{"YES","NO","Cancel"} S4
      if input == 0
          set var.set_temp = true
      elif input == 1
          set var.set_temp = false
      else
      T3P3Tonyundefined chrishammundefined 2 Replies Last reply Reply Quote 0
      • stuartofmtundefined stuartofmt marked this topic as a question
      • T3P3Tonyundefined
        T3P3Tony administrators @stuartofmt
        @stuartofmt would it be possible for you to test this on standalone mode easily or is it a lot of faff to change things to do that?
        www.duet3d.com
        stuartofmtundefined 1 Reply Last reply Reply Quote 0
          stuartofmt @T3P3Tony
          @T3P3Tony said in [3.6.0-beta3] Macro race condition?:
          Hmm - I'm not sure what would be involved. Move the SD card from Pi to Mini then just power up the mini? Or is there plugging and unplugging etc.?
          • T3P3Tonyundefined
            @stuartofmt you would need to make the "SD card" directories in the FAT/boot partition of the SD card (or update the files if the directories are already there). Basically what is in /opt/dsf/sd needs to be copied into the boot partition. Also assign an IP address in that config.g or set to DHCP as appropriate. Alternatively start with a fresh SD card and put copies of the directories there.
            With an SD card in the Duet is should boot into Standalone mode.
            www.duet3d.com
              @T3P3Tony
              Got it - will try to get it done over the weekend.
              I'll just create a new SD card likely the quickest.
              stuartofmtundefined 1 Reply Last reply Reply Quote 1
                stuartofmt @stuartofmt
                @T3P3Tony
                Well, that was fun ... I've moved countries and eventually found the external antenna in a box of bits. It was only then that I realized the Mini5+ is ethernet and said antenna was for something else. The house is wifi only. Getting the printer, safely, to the router in the loft (for an ethernet connection), is a faff too far 😞
                chrishammundefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
                • chrishammundefined
                  chrishamm administrators @stuartofmt
                  @stuartofmt Thanks for reporting this, I could reproduce it. I'm going to fix this before we release 3.6.0-beta.4.
                  Duet software engineer
                    @stuartofmt I've got a fix ready for the upcoming v3.6.0-beta.4. In SBC mode, sometimes DWC wasn't informed about updates of state.messageBox.choices. That could only happen when state.messageBox wasn't changed to null before another message box with choices was opened. I guess if you add a delay of 250ms or more between the M291 calls, the problem doesn't show up.
                    • T3P3Tonyundefined
                      @stuartofmt sorry for the huge faff. I am glad Christian managed to id the issue.
                      www.duet3d.com
                        @T3P3Tony
                        No need to be sorry - I had to figure out what else was in the boxes anyway 🙂
                        And thank you Christian. I though I was seeing things at first 🙂
                        • stuartofmtundefined stuartofmt has marked this topic as solved
                          @chrishamm @T3P3Tony
                          I just tested with 3.6.0-beta.4. I can no longer trigger the behavior.
                          Looks good!
