Duet 2 v1.02 not responding
@droftarts Tractus 3d T650P is my printer
A part of the config.g couldn't be copied (2 reputations or something error)
@thomasvanderwal Your Tractus is a delta printer, but your config.g is set up for a Cartesian printer? Do you have an old config that worked?
Otherwise, see https://docs.duet3d.com/User_manual/Machine_configuration/Configuration_linear_delta
@droftarts no, a colleque got this printer from a company. He's gone
I am a educator at a technical school. -
@thomasvanderwal Okay. I think start again with the configuration tool, but this time select "Linear Delta" for Kinematic type. https://configtool.reprapfirmware.org/Configuration#kinematics
Tractus3D have renamed/been taken over by https://nexum3d.com/. You may be able to contact them and get them to send you a standard configuration for your machine. They are a Dutch company based in Amsterdam, i believe.
@thomasvanderwal said in Duet 2 v1.02 not responding:
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.0 running on Duet Ethernet 1.02 or later
Now that you're seeing some progress it may be a good time to update your firmware before you get too far with configuring. 3.0 is quite old now.
If you have access to DWC, you should upload the following zip files one at a time. It will prompt to install the firmware and restart. Then upload the next version, etc.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
https://github.com/Duet3D/RepRapFirmware/releases/download/3.5.4/Duet2and3Firmware-3.5.4.zipThe reason for uploading 3.0 again is to ensure all of the required files are present.
