    6HC Ethernet PC WOL?
    • wayneosdiasundefined
      wayneosdias
      Is anyone using Wake On LAN aka WOL with Duet Ethernet?
      I'm currently laid up daydreaming about putting my i5 NUC inside the chassis of my Duet 6hC+ethernet/Openpnp PnP machine. I'm successfully running Openpnp between the NUC and 6HC on ethernet/tcp and want to relocate the NUC into the machine chassis. One issue is access to the NUC power button. In looking into remote power buttons, I found the Wake On LAN boot function.
      • T3P3Tonyundefined
        T3P3Tony administrators @wayneosdias
        @wayneosdias There is no WOL functionality in the 6HC, however you can run it with an external 5V supply and then send commands to the 6HC to have it turn on the main power supply (assuming that supply is controllable remotely.
        www.duet3d.com
        wayneosdiasundefined 1 Reply Last reply Reply Quote 0
          wayneosdias @T3P3Tony
          @T3P3Tony Thanks for confirmation. Ill look into other options.
